Re-plating soldering iron bits
Conundrum, Wed Jun 13 2007, 03:29PM
Hi all.
This one has been bugging me for a while. For some stupid reason every single cheap soldering iron I have owned, be it iron-over-brass or iron-over copper has failed due to bit erosion.
I have found a way to effectively replate them however.
Obtain a surplus ball point pen, some steel wool, bicarbonate of soda, syringe/needle and soldering iron bit.
Get 100ml of water (ideally deionised) and stir in as much bicarbonate of soda (NaHCO3) as will dissolve. I used one teaspoon.
Sand the bit and/or shape to correct form to remove SMDs etc then clean it with isopropanol.
Then, get your ball point pen, cut off a 1" section of the barrel and stuff it with steel wool up to the end.
Use the syringe and needle to inject the bicarbonate solution until the wool is saturated.
Poke a small hole in the top of the pen, and insert a multimeter electrode. The other end of the multimeter connects to the positive side of a constant current supply with a maximum voltage of around 12-15V.
Connect the soldering iron bit to the ground side.
Adjust the constant current supply so that the iron bit is *just* bubbling, too high and it may not correctly plate. 0.3A on mine.
You will need to leave the setup at least an hour to plate properly, I recommend removing it after half an hour and gently abrade the plating with a tissue to get rid of any debris.
Hope this helps someone.
-A
Re: Re-plating soldering iron bits
..., Wed Jun 13 2007, 05:20PM
Hmm, I usually just dremel down the tip and go from there. The tips I use are generally solid brass, sometimes I need to add a little flux but I have never had problems with getting the tip tinned.
Conundrum, Wed Jun 13 2007, 06:11PM
its not tinning that is the problem, its tip erosion :)
-A
ragnar, Wed Jun 13 2007, 10:42PM
I've seen some nifty 'rejuvenator' products which are only recently sold at a store where I work. They seem to be just flux and tin, though. GOOT brand, so they can't be too bad, right?
Bored Chemist, Thu Jun 14 2007, 05:51AM
Using a solder that contains copper can help.
thermite, Mon Feb 18 2008, 12:43AM
Your description does not tell what metal is being plated on the copper and what is the anode and what is the cathode.
Conundrum wrote ...
Hi all.
-A
