  • Guests: 26
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Terry's Tesla Tuner
Tesladownunder
Fri Jun 01 2007, 12:16PM Print
I built up Terry Fritz's Tesla Tuner today.
I used a 10 turn pot that I had on hand and various "near enough" parts.
Seemed easy enough and oscillates from 6 to 400kHz.
My big TC resonates at 41kHz. I remember it was meant to be 37KHz but I ran short of wire.
I read off from my frequency meter in my DVM.
I built it because I do a lot of variable topload stuff with different length rotating rods and was looking for a more accurate method of tuning.
TDU
1180699987 10 FT0 Teslatuneron
1180699987 10 FT0 Teslatunerinside
1180699987 10 FT0 Teslatunerrunning
Reaching
Fri Jun 01 2007, 04:52PM
Very cool. i had to try it immediatly and i think its a cool way to measure your sec frequency. But for those who have higher requirements or want to be more accuratly its waste time.especially if you dont have a frequency counter.
Fri Jun 01 2007, 05:45PM
Nice. I was going to make one too, but the frequency range was too low. Another possibility is to use a fast op-amp as a square wave generator. Unfortunately the only op-amps I had went to 400kHz, about where the 555 topped out too!
Hazmatt_(The Underdog)
Fri Jun 01 2007, 11:28PM
Reaching, why don't you check the thread World's simpliest frequency counter.
I think I'm gonna throw my counter on this little guy and make a neat digital tuner.
Thanks Terry and TDU.
Electroholic
Sat Jun 02 2007, 05:00AM
humm, I think this would be a good uC project.
Mon Jun 04 2007, 03:17AM
I took a little bit of time and made a direct tuning indicator for you guys. You can now see the needle maximum and deflection as you tune.
The current meter should be less then 1mA. 1mA seems to be a pretty big current requirement for the standing wave tuning, but a meter of a couple hundred microamps works quite well.
My meter says DC Kilovolts, but its really a 200uA meter FSD.
1180927035 135 FT26150 Vswr
007f
008f
********** Update ***********
My tuner is coming along with 2 ranges, Lo and Hi. The VCO will cover ~8KHz - 500KHz for the big coils, and 34KHz - 2MHz for you guys doing small coils. It will have a fine tune also!
I can't wait to show it off when its done.
