  • Guests: 29
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
pre-accelerator
JoeDarkon
Thu May 24 2007, 04:29PM Print
JoeDarkon Registered Member #485 Joined: Sun Jul 09 2006, 01:14AM
i was wondering if it would make a noticeable difference if i accelerated the projectile (pneumaticly or with a spring) before it went through two coils as opposed to us the first coil to start it off
Bjørn
Thu May 24 2007, 05:59PM
The energy that you transfer to the projectile in any pre-stage will not go disappear so the final velocity will be higher. If it makes sense depends entirely on why are making a coil gun.
A gun based on compressed gas will be far cheaper and more powerful than a coil gun so it would be a strange combination. If it is for fun, learning or to achieve a very accurate velocity then it might make sense.
Simon
Fri May 25 2007, 05:52AM
IIRC, someone in Japan tried this. Along with Bjørn, I'm not sure why there'd be a practical reason to combine compressed gas with EM.
Since (I'm assuming) the bulk of your energy will be in the capacitors, anyway, there won't be any major efficiency advantage over a multistage design.
TheMerovingian
Fri May 25 2007, 11:06PM
The best preaccelerator is a coilgun itself or a solenoid + spring combination. I'm using this configuration for my semiautomatic magnetic submachine pistol where a solenoid is used to kick the projectiles out of the magazine into the coil barrel for further acceleration
