  • Guests: 28
a.gutzeit (63)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
New coil Gun
Sat May 26 2007, 09:03PM
You really ought to have that SCR in a clamp, not for heatsinking, but for proper internal connections (the end plates need to be compressed against the silicon wafer inside). Without a proper clamp, you run a very high risk of generating "hot spots" on the wafer which cause premature failure.
The biggest lytics ive seen are my 15,000uF 350V ones (and im sure on that one :P).
Danielle
Sat May 26 2007, 11:52PM
Danielle Registered Member #632 Joined: Mon Apr 09 2007, 01:09AM
I did have problems with the SCR one time I fired it and the wires welded to the SCR. but I put it in a regular C clamp with plexiglass in between. I didnt have it mounted in the picture.
