  • Guests: 10
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Insulators and heat sinks for power transistors - are they essensial ?
JamesH
Thu May 17 2007, 06:25AM Print
JamesH Registered Member #579 Joined: Mon Mar 12 2007, 09:45AM
I have recently seen an a rticle that says MICA insulators and insulated fixing screws/bolts are essensial if one is to prevent transistors shorting out when used to drive HV circuits ... Ignition coils or Flybacks.
What is the consensus?
I have blownlots of 2n3055 in Ignition coil and LOPT drivers
I have not used any mica insulators or insulating fixings
SHOULD I HAVE DONE
My reasoning is:
if the fixing bolts need to be insulated why does the manufactureres always make can or tag the collector
I can never find any one , locally, that stocks mica insulators and I am not going to order some by mail and pay £4.00 postage and some times £20 minimum order charge
I could make the insulator pads from something else : rubber or polyethylene but that would then thermally insulate the transistor from the heat sink
All comments and suggestions appreciated
thedatastream
Thu May 17 2007, 07:17AM
JamesH wrote ...
You only need to insulate the tab of a transistor if something else is connected to the same heatsink that is not at the same voltage.
This could be if you connected another transistor of a half bridge to the same heatsink for example, or if the heatsink was bolted to an earthed chassis.
James
Thu May 17 2007, 12:54PM
Where possible I prefer to not use insulators between transistors and heatsinks, just thermally conductive paste.
The cooling of the transistor is much better, at the cost of insulating the heatsink.
Simon
Fri May 18 2007, 03:50AM
JamesH wrote ...
But you have used lots of 2n3055s. If you use the 2n3055 for real experimentation and push it hard enough, you're bound to blow a few. It's beefy enough when it comes to power but just isn't designed for HV work. (It's still popular for hobbyists because of cost and availability.)
If you can hold of an MJ10012, it's worth it. It's available in Australia at Jaycar but I understand you're probably limited to RadioShack for local electronics shops...
teravolt
Fri May 18 2007, 04:16AM
at one point I had to bite the bulit and bought 500 mica insulatos for TO-247. They have a higher voltage hold off and thermal caristics. You can get them at Concord electronics and Keystone electronics. That may not be your problem if you are using silicone insulators and voltages bellow 600V. If every collector is insulated properly try grounding the heat sync. If you paralelling collectors you could get rid of them all together
