  • Guests: 24
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Why are my power transistors blowing in my flyback driver ?
JamesH
Thu May 10 2007, 05:00PM Print
JamesH Registered Member #579 Joined: Mon Mar 12 2007, 09:45AM
This is a beautie....... I have built a flyback driver ... one 2n3055 plus two resistors one FB coils and one primary coil
It works well on 5 LOPT, all different sizes
BUT I have blown 5 transistors now and they seem to blow AFTER I have left the driver disconnected from the 12volt battery ?????????
Twice, I have left the circuit over night, battery totally disconnected, and the 2n3055 have blown the next morning ... no start up spark at all
To day I have made another circuit up - worked great ... disconnected the battery .. went to do some work in the garage for 1hour - came back no sparks ... transistor blown
What is going on?
Stored energy I suppose ( thats how lopt work) so how do I prevent it?
Diodes in the battery line ? will that stop the chopping / pulsing ?
diode in the base line ... surely not?~:-(
Any body got a bulk supply of power transistors ;)
can I replace the 2n3055 with a mosfet irf 740 ?
Thu May 10 2007, 06:02PM
Build a driver using a 555 timer and a FET (IRFP250/IRF540/IRF640 etc.). It is a bit more complicated but its performance is magnitudes better.
Thu May 10 2007, 06:36PM
The single 2N3055 driver isn't too reliable, and very inefficient. Upgrade to a better driver. Using a mosfet would not work, that driver needs a transistor.
Michael W.
Thu May 10 2007, 10:53PM
Michael W. Registered Member #50 Joined: Thu Feb 09 2006, 04:07AM
Try reversing the feedback wires, worked for me.... cheesey
