  • Guests: 28
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
High voltage on Water vs. Water vapor
Doug
Thu May 10 2007, 03:11PM Print
Doug Registered Member #698 Joined: Thu May 10 2007, 01:03PM
I've noticed what appears to be a different reaction to an electric field
for water as a liquid and water vapor. However, I don't have a VDG to
test this with a stronger electric field, and I wondered if anyone has
noticed this as well.
Situation one: Glass of water vs. electrically charged glass rod.
When the charged rod is moved over the water, it moves up towards
the charged rod forming a cone-like structure before discharging with
a snap sound. After the snap the water returns to a rest position and
there is significantly reduced electrical charge on the glass rod.
Notes: No appreciable difference between normal tap water, distilled water,
and salty water.
Situation two: Humidifier vs. electrically charged glass rod.
After generating some cool water vapor via humidifier and then placing it in
an insulating container, the electrically charged rod is moved towards the
mist in the container (ice cream as it turns out). The water vapor flows
away from the charged rod and will overflow the container to avoid the
rod. After removing the rod it seems to have no appreciable "wetness"
or loss in electric charge.
Note: The uncharged rod also causes mist to flow, but not to the extent
that an uncharged rod does. i.e. only via displacement of air.
So, basically it seems like the water as a liquid is being attracted to a
high voltage source, while the water vapor is being repelled.
What I'd really like to do is get a VDG and put a wire from the sphere
into an otherwise completely insulated container and see the effects
from a stronger electric field than I can generate using glass/silk methods,
and to that end I've started to put together a VDG, but in the meanwhile,
has anyone seen a similar effect?
For example, mist around powerlines in the morning perhaps? Or otherwise
simply things experienced while using a VDG?
It strike me as odd that the typical advise that is high voltage sources leak
and ground themselves if there is high humidity, but that doesn't seem to
be the case at all in this (not particularly high voltage) example.
cheers~
Doug.
Dago
Thu May 10 2007, 03:22PM
Dago Registered Member #538 Joined: Sun Feb 18 2007, 08:33PM
Your tap water is grounded (opposite polarity compared to your glass rod) and your mist is not so the water particles get charged by the rod and get repelled.
Doug
Fri May 11 2007, 12:38AM
1) My tap water is grounded? Its in in a glass (ie. insulated container). not streaming out of the tap. Besides, water coming out of the tap attracted to a charged object via induced surface charge (see lord kelvins water dropper electrostatic generator).
2) If the particles get charged and repelled by the rod there should be a constant stream of uncharged particles moving towards the rod, getting charge, and moving away. I don't see that happening; and if it did, the charge on the rod would surely drop, which it doesn't.*
* edit: Appear to.
YoshiEggz
Fri May 11 2007, 09:37PM
YoshiEggz Registered Member #521 Joined: Wed Feb 14 2007, 06:03PM
I would think it may have something to do with air partials between water vapor changing the Permittivity of the overall system. I will give it a try with my 100Kv supply and some artificial fog. It's interesting that it displaces it though, almost as if there was a forcefield around it with enough pressure to offset the air pressure.
