  • Guests: 35
GODSFUSION (37)
Zajcek (37)
ElectroDog (33)
sportcoupe (56)
04/30 BlakFyre (36)
04/30 SENTRY (31)
05/01 Shaun (34)
Plasmasonic Audio Modulated Tesla Coil (Video)
Sat Apr 28 2007, 12:35AM Print
Here is a video of my original Plasmasonic audio modulated system with a cool looking electrode.
The music is "Deliverance" by Yanni.
Enjoy!
http://www.youtube.com/watch?v=6tKo_3DzdSU
Ken M.
Sat Apr 28 2007, 12:37AM
Wow EVR That has to be 1 if not the best sounding Audio modulated TC I've seen
Sparrow338
Sat Apr 28 2007, 12:44AM
Sparrow338 Registered Member #661 Joined: Sat Apr 21 2007, 03:17AM
Very nice job EVR. Definatly the best audio modulated coil i have seen. On your youtube post you say it is stero, how would that work though if there is only one arc/coil?
Sat Apr 28 2007, 01:34AM
wrote ...
Thanks. The quality is pretty good, although because this design switches at 350kHz, corona hiss is still present. But it is a trade-off between volume and quality. This coil can put out up to 2kW and really crank out some volume, including low bass, especially with the large surface area electrodes. Higher frequency designs (3MHz+) are virtually silent and produce really clean sound, but lack the volume since they cannot produce (at least not easily) the power that a lower frequency unit can produce.
Electric Genie wrote ...
Thanks. Yes, the Plasmasonic system is stereo, however, i'm only showing a single unit here. The whole system utilizes two identical coils for stereo operation, and the effect is absolutely stunning. The imaging is incredible with stereo operation and sounds pop from seemingly nowhere, especially when using small point-source like electrodes.
This video shows the standard configuration of the Plasmasonic electrode.
http://www.youtube.com/watch?v=M-EaxOig-UY
Sparrow338
Sat Apr 28 2007, 01:59AM
That is really amazing, must seem really cool when the sound seems to come from nowhere. It's so cool how the corona discharge changes with the sound; for the high points of the sound it puts out a larger discharge, really gives it a dramtic look. Does changing the electrode size or shape affect it's sound in any way? What does the audio modulate? Is it frequence or input power, or maybe both?
Awesome job, keep up the great work! smile
ragnar
Sat Apr 28 2007, 02:35AM
As a matter of principle and personal preference, I prefer more moderate volumes and crisp, perfect operation. That's why I've been working on these 9MHz and 13.56MHz coils. I do like the great amount of.. 'excursion' (hehe) you're able to get from your larger system. At 350kHz, you could be running the coil itself from a TL494?
Don't stop at stereo. Try quadraphonic! You'll be pleasantly surprised, as I was with my four-way 4MHz system. (I really had to settle on 4MHz, because that was the fastest I could push IRFP450s with the gatedrivers I had on hand.)
The VU meter is a nice touch.
Sat Apr 28 2007, 03:10AM
Thanks.
Yeah, i've done extensive work with 10MHz coils about 3 years ago for the next generation Plasmasonic and they worked great (they used IXYS RF MOSFETs) - sounds was definitely pristine, but just didn't have the volume i was looking for (especially since i do lots of demonstrations for large groups of people) and also since they were low power, they suffered greatly from low-end response. The plasmasonics, with the circular electrode, can really push the lows quite well.
Coronafix
Sat Apr 28 2007, 11:37AM
I was looking at your Plasmasonic papers on your site some time back and was really impressed with your work, so I'm glad that you posted this vid so that I can just tell you how great I think it is. Well don Dan.
Never thought Yanni could sound so good. wink
Sat Apr 28 2007, 02:52PM
Thanks for the comments!
Yeah, I'm not a big fan of Yanni either, but this one piece sounds pretty good on this thing!
WaveRider
Mon Apr 30 2007, 07:01PM
Hi Dan,
Yanni or not, your Plasmasonic was my inspiration for dabbling in audio tesla coils...
Cheers!
