  • Guests: 52
Inducktion (32)
Standa (31)
nabzim (33)
12/23 David (39)
12/25 Kolas (18)
Cheaper alternatives to Basic Stamps
ConKbot of Doom
Sat Feb 17 2007, 08:33AM
Brett Clark wrote ...
Thanks for the info guys, the PIC16's look pretty good, quite affordable.
That ARM is a beast, nothing I'm doing now would even be worthy of it.
Going to switch my front door over to RFID, now only if I could get my hands on some sub-dermal tags...
or possibly a nike + Ipod unit for starters cheesey
thedatastream
Sat Feb 17 2007, 09:26PM
thom wrote ...
I would recommend Atmega88 (23 I/O, 8k prog, 1k ram) ~$3.80, or another AVR.
The C compiler and IDE for it are free (no restrictions) and heavily supported.
I would second AVRs, but that's only because I never got the hang of PICs and drifted onto AVRs via the 8051/2.
I like the ease of programing an AVR and I use the AVRISP - a 6 pin programming interface - to stuff my devices.
James
Carbon_Rod
Sun Feb 18 2007, 01:23AM
Bjorn, Is vectorizer open source? It looks interesting... I had built something similar, but switched to a digital PWM system instead for its stability (used as an emf renderer).
The USB based boot loader PICs are nice for most things (~24KB @ 48MHz + USB + serial com module.) C compilers are only good if you plan to write an interrupt based scheduler to guarantee timing for some things. (most C compilers for PIC are overpriced garbage, except the DSPIC series that use a gcc.)
ARM is nice too (note the good chips seem to be SOIC only), but the ARM gcc tool chain is good.
Bjørn
Sun Feb 18 2007, 05:49AM
Vectorizer is not open source, but I am usually very helpful.
C compilers for very simple projects can be more trouble than they are worth. A competent programmer should be able to learn the PIC instruction set and make small useful programs with perfect timing in an afternoon.
One of the problems with gcc for ARM is that if you use some functions like printf it will include about 30kB of code that will never be executed and it will quickly sink your project unless you know how to hack away at the libraries.
There are some cheaper alternatives to basic stamps like http://www.rev-ed.co.uk/picaxe/
Carbon_Rod
Sun Feb 18 2007, 07:36AM
Have you tried gcc -O2 to run the optimizer ;-]
Also note the gcc is bad at byte alignment and padding for struct's. This is what causes constants in rom space to mysteriously lose space. Sometimes, what is normally bad code (or a trivial performance loss) on a PC will actually work better on a uC.
As for libs, most people have to write their own print() function to drive whatever display they plan to use.
