  • Guests: 39
Adam Munich (30)
Alfredo Texacca (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Fill your backyard with sparks
Tesladownunder
Sat Jan 27 2007, 12:57PM Print
I was unhappy with my 4inch TC so I gave it an upgrade.
Do you like it wink
Peter
1169902658 10 FT0 Fillyourbackyardwithsparks
ragnar
Sat Jan 27 2007, 01:29PM
Holy cow... I'm guessing you've got a motor running from a 12V battery on top of the topload, spinning a wire? Hehehe
That's absolutely brilliant... I should take a multiple exposure photo of my 13.56MHz TC positioned in 712 different places around my office... but it still wouldn't compete =)
Will see what I can do, though, heheh
Sat Jan 27 2007, 03:14PM
Yikes! What's the exposure time?
Dr. Slack
Sat Jan 27 2007, 11:40PM
Damnit, Red Led Suntan OW, don't you ever stop doing cool stuff, that I would have done had I thought of it first!
Hazmatt_(The Underdog)
Sun Jan 28 2007, 12:36AM
Wow! I'm gonna need a bigger backyard.
Tesladownunder
Sun Jan 28 2007, 01:35AM
balsamplack wrote ...
Holy cow... I'm guessing you've got a motor running from a 12V battery on top of the topload, spinning a wire? Hehehe.....
How could you tell it was 12V? I only used 12V because a sparkthrough toasted my 9.6V pack frown
I had a 24V motor ex aircraft with solid reduction gears that fitted in the PVC extension at the top of my TC. It rotates a 2cm aluminium tube which projects about 7ft on one side and 1 foot on the other and is counterbalanced with loudspeaker magnets and some microwave ferrite magnets. Rotation is about 1 rotation in 13 secs powered by a 12 Volt SLA battery wrapped in foil after my NiCad experience.
It turned out well in the end for only a few hours work to develop it with parts on hand. I don't recall seeing anything similar anywhere else. Really its impact is primarily photographic though but the exposure for 1 RPM makes even a small coil cover a great area with sparks.
Photo shows the setup.
Peter
1169948138 10 FT20123 Teslarotbreakoutsetup
