  • Guests: 10
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Printing a PDF to get a book
thedatastream
Fri Jan 19 2007, 03:06PM Print
When reading more complex datasheets or text documents, I like to print them out to read them and make notes in the margins etc. To save paper and space, I print out full duplex (on both sides of the paper) and two portrait oriented pages to a single landscape A4 sheet.
What I really want to be able to do is to order the pages so that I end up an A5 booklet that I can cut down the middle and staple together to form a conventional book. So for a 8 page PDF, I would want to print the pages in this order:
8 | 1 > 2 | 7
6 | 3 > 4 | 5
where
'>' denotes moving to the other side of the sheet of paper
'|' denotes the centre of a page
I can now cut the pages down the middle and it forms a book with the first page on the outside.
Is there a way of doing this? Prefereably automatically as manually setting up this would be a chore.
Thanks
James
Simon Barsinister
Fri Jan 26 2007, 01:45AM
Simon Barsinister Registered Member #116 Joined: Fri Feb 10 2006, 03:19AM
The Toshiba copiers (printers) I work on do that function. It is called "magazine sort". Probably moot as I am guessing what you are looking for is a way of doing it on your pc /printer.
Rich
Dr. Shark
Sun Feb 04 2007, 02:55PM
I used to have some Windows software which did exactly what you want. I forgot the name, probably it was something like "Print Studio", you should be able to find it with google...
ragnar
Mon Feb 05 2007, 06:29AM
James, you'll find FinePrint will do exactly what you need and more.
Have a read of their tutorial, here:
http://www.fineprint.com/support/fineprint/tutorial/index.html
to see if you like it. I use it for printing manuals and stuff; it takes all the brainmulling and frustration out of duplex printing.
Matt
Part Scavenger
Thu Mar 29 2007, 02:06AM
If anyone still cares, they call it "impostion" Some MSWord related sources call it "booklet print" I've seen it referred to as N-up and 4n-up as well. Thought that might help, CutePDF (free) is supposed to do a good job although they *just* went to try-b4-buy. I'll bet you won't have to look hard to find an old link that works.
Some said the route to go was to get a printer driver instead. Here's HP's Link2
I haven't had time to mess with it yet, hope it works out.
