  • Guests: 40
Kolas (18)
Dillon4DynamicHarmonics (41)
12/26 buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
Genetic programming
Bjørn
Wed Jan 17 2007, 04:26AM Print
I have developed the pseudo random generator search program to a genetic algorithm where each gene is a machine code instruction. It evolves the solution to a function expressed in the source code of the program. It works quite well for many simple functions and some times discovers solutions that are not completely obvious. For example it finds optimal solutions to functions like R0=R0*164 without problems:
ADD R1,R0,R0,LSL #2
ADD R0,R0,R1,LSL #3
MOV R0,R0,R0,LSL #2
As expected there is a fundamental problem that puts a serious limit on how well it works on non trivial functions. The genes have these properties:
1. Changing all bits in a gene might not change the function of the gene.
2. Changing just one bit may change the function completely.
This means that the search space is not smooth at all and contains many walls that requires several very unlikely mutations to traverse. To put it another way, a gene that gives a near perfect result may be completely wasted because the perfect result may require a completely different gene. and the evolution will be stuck at a false optimum until mutations happen to traverse the wall. To make things worse getting stuck at a false optimum causes the genetic variation to sink as most genes are slowly replaced by genes of the same type as the false optimum, this makes progress even less likely.
So any changes that smooth out the search space by even a small amount will cause a large improvement in efficiency. Using machine code instructions directly as genes seems like a particularly bad idea, something more abstract like reverse Polish notation will probably work a lot better but be far more complex since it will require several additional steps to end up with optimal machine code.
Madgyver
Wed Jan 17 2007, 06:36AM
Interesting, what scheme are you particulary using? Do you use 1 individual and mutate it until the solution fits, or do you use a bunch of individuals and let them recombine?
Bjørn
Wed Jan 17 2007, 07:00AM
I have 2048 programs with N instructions in each, usually N=4 since it is enough to do interesting things and still does not take days to complete.
I compare the output from each program with the target function, then I sort the programs after how well they fit.
The plan was to let the most fit programs reproduce and over write the least fit ones, but that did not work well. The result was lots of upper class snobs with very little genetic variation and there were no progress. So instead I just select two and two instructions by random to breed new instructions. The mutation stage inverts 0.1% of the bits on random.
Then I repeat the process until the fit is 100% or I get tired of waiting.
JimG
Thu Jan 18 2007, 02:05AM
JimG Registered Member #52 Joined: Thu Feb 09 2006, 04:22AM
I tried my hand at genetic programming almost a decade ago and found it to be a lot harder to get working than a genetic algorithm. You seem to have run into the same problems that I did. Your fitness function could send you in the wrong direction and changing a single bit can generate wildly different values.
To get around the issue of changing a single bit causing major changes I used a tree where a node could be a math operation, memory operation, or constant value. Since math or memory operations would create or destroy new nodes then they were set to a lower change percentage. This also meant that the program size was not constant and reproduction was asexual. RPN might work just as well as a tree.
My fitness function also had to take into account different aspects of fitness. For instance one of the programs I was trying to do was a sort algorithm, so I had to check how well sorted the values were, if the values changed, and how many of the new values were in the original set.
