  • Guests: 21
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
Downloading flash animation with linked files
Nucleophobe
Sun Dec 31 2006, 08:51AM Print
Nucleophobe Registered Member #108 Joined: Thu Feb 09 2006, 11:44PM
Any idea how I would go about making this study resource available offline??
I've tried saving the main file, copying all the files from the temp, and everything else I could think of but it never loads up quite right. Any advice appreciated!
stop4stuff
Sun Dec 31 2006, 11:04AM
stop4stuff Registered Member #64 Joined: Thu Feb 09 2006, 06:25AM
in IE 6.0
goto the page online,
click Add to Favorites
click the checkbox 'Make available offline'
IE 6.0 does some sychronisation thingy
when you want to view the resource offline,
open IE 6, click 'File' (top left), then click 'Work Offline' then click on the link in 'Favorites'
from playing around, don't 'Delete Files' in Temporary Internet Files as it deletes the other files that 'shell.swf' uses.
Sun Dec 31 2006, 04:56PM
Wow, I think that is the same book we used in ap chem suprised Suddenly I am having flashbacks of Ms. Vorak lecturing about thermodynamics...
In any case, you might try a program like httrack, but it might not be 'smart' enough to only download the part you want. I have a feeling that downloading the whole site would take a little while ;)
I think that the reason that you can't just copy the files from the tempory directory is that the locations of the files are hard coded into the app, so you need a program that will change that to somewhere local (but I am not sure about that)
Nucleophobe
Sun Dec 31 2006, 07:19PM
Hehe, yea, I used Zumdahl 3rd ed. in honors chem almost 4 years ago now. The text was a little thick for me then. Thanks for the comments.
After I make it available offline, is there anyway to copy the cache? I was hoping to make it available to a friend (although I could just tell them how to do it, too)
As well, unless I carefully go through and click on all the chapter resources one-by-one, they are not cached and hence do not work offline. I need something like httrack or curl for a embedded flash animation or.. k I don't really know what I'm talking about.
I looked on Google, the problem is I don't know the proper terminology...
Carbon_Rod
Mon Jan 01 2007, 11:33AM
"Black Widow" web tool had a plug in that could do swf.
wget will not... =[
There is also a decompiler out there for swf that integrates into IE too.
Try to take Zumdahl in stride, most of the really interesting stuff is in other books later on.
Cheers,
