Banned on April 7, 2007 Registered Member #277
I'll bet someone has discussed this before but I can't find it in the archives. I'd like to know the time duration of a spark jumping a 1cm spark gap, ie: how many nanoseconds does the spark exist? I realize there are 100 and 1 variables such as humidity, oxygen content of the air, the diameter of the spark gap spheres, and the question is broad, but anybody venture to make an educated guess or point me to a chart somewhere that shows this info? Yes, I googled it too, but nothing definative. Thanks in advance. CM
Registered Member #103
I would think it is simply 'as long as the power supply can sustain it'. You need to reach the breakdown voltage for the spark to initially strike, that's determined by a number of factors as you mentioned, but to sustain it you need to keep a current flowing...
Sorry, I should have been clearer. Assuming the spark events are seperated in time, ie: one spark jumps a 1 cm gap (two spheres compose the gap) about every 5 seconds, I am wondering how many nanoseconds the spark exists. Odd question I know, but maybe someone might have this info. The U.S. goverment pays millions to study the mating habits of the purple peckered termite during full moonlit nights, I assume somebody somewhere has looked into spark durations at sometime, just wondering if anyone knows where I might find that info Thanks. CM
Hmm, unless I don't quite understand what you're asking, I'll stick by my original answer. The only reason a spark would extinguish in the first place would be because the power is removed or reduced, which is usually a tank capacitor discharging through the spark gap. When that happens, the spark cannot re-initiate until the breakdown voltage is reached once again, so you get the rhythmic sparking. In this case, the duration of each spark would depend mostly on the capacitance of the capacitor bank.
Here is my take on what happens. Take it with a grain of salt as I made most of it up.
The spheres have a capacitance of a few pF which will discharge rapidly limited by the resistance of the arc and the inductance of the 1cm path giving a discharge at a guess in 10's of ns. What follows should be some ringing between the inductance of the path and capacitance of the spheres. with the ring down dependent on the resistance of the arc channel which is dependent on temperature and presumably total current that passes in that short time. Probably a few cycles of the same period ie another 20 - 30ns.
After that current flow will depend on the ability of the supply to give a current limited output. Consider DC first. If the supply is terminated in a capacitor then current is delivered in a burst as the capacitor is discharged. This is slower and more likely to take microseconds rather than nanoseconds but after that there is no current flow while the cap recharges. The stored energy will give a bright single blue spark. It will also ring for a bit in the following microseconds or more. If the supply is terminated in an inductor the current comes in slower again, in milliseconds and persists longer, also with ringing. It will resist breaking as this would interrupt the magnetic field of the inductor. The arc is soft, quiet and purple (or orange if sodium is present). If the supply is terminated with a resistor the current can continue to be supplied slowly continuously. Average current is low. The arc is softer and more easily extinguished.
An AC supply is similar provided things happen in a timeframe less than the period of the AC. 50Hz AC will be different to 100kHz of a TC. The spark channel remains ionised for perhaps hundreds of nanoseconds after the spark passes but remains hot and a preferred path for a new spark for some milliseconds.
Peter (Tesla-never-answer-a-simple-
yes-or-no-downunder) Pic shows a ringing spark of a TC at 100kHz viewed with a streak camera. The ringing originates from the TC rather than the gap and is a bit different to what I am talking about but helps give you the idea.
Registered Member #354
I read that discharge through a spark gap happens until discharge of capacitors to an about 40% of breakdown voltage. Also I read that arc impedance goes to 0 as more current came in, so the spark duration may be driven by overall impedance. If you use an inductor, tha capacitor bank plus inductor make an oscillation (w^2=1/LC): it can be good in order to avoid to electrode be electron empty. The spark gap also stores a lot of energy because low induction but lots of amps E=0.5*L*I^2. If you set a serial inductor L1 to a spark gap: L2 then the energy stored (and released) at spark gap will be reduced to a factor= L2/(L1+L2)
Registered Member #162
Maybe the question you're really asking is - how brief can a spark be? Using special spark gaps and co-axial capacitors - tens of nanoseconds is the answer. Small value capacitance with minimal series inductance in the discharge loop is required.
Registered Member #83
Look at TEA Laser keyword on the internet. Transverse Electrical discharge in Air - this is basically to get as short duration sparks as possible. Involves minimum inductance, etc.
