  • Guests: 16
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
AIA format for chromatograhpic data
Bored Chemist
Tue Nov 28 2006, 09:29PM Print
OK, I realise that I mighht be better off looking on a chemistry website for this but I like it here and the natives are friendly. cheesey
Does anyone have any idea what the header data is for an AIA file or does anyone have such a file they can send me so I can try to work it out for myself?
(For those who haven't given up reading yet. AIA is a "standard" format for exchange of chromatography information. I need to get some data into a chomatographic data analysis package and I don't know what "null" header data I need to add to get the systm to recognise the file. Just in case you are wondering, the system doesn't generate AIA files but it does claim to read them)
Bjørn
Wed Nov 29 2006, 12:02AM
If I figured it correctly then it is the Analytical Data Interchange (AnDI) format developed by the Analytical Instruments Association (AIA).
AnDI is based on the netCDF format: Link2
The andi package Link2 has sample files in the netCDF format included in the .ZIP.
Simon
Wed Nov 29 2006, 12:16AM
If you search on the web you'll most likely find some conversion software. I had a try myself and it looks like AIA is now called CDF.
I think the natives here are out of their league on this one - unless you can find some technical specs or a sample file.
Edit: Bjørn beat me to it.
Bored Chemist
Thu Nov 30 2006, 06:33PM
Thanks folks, with a bit of luck I can sort out how to get my data in and out of the system now.
