  • Guests: 26
Adam Munich (30)
Alfredo Texacca (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Approx self-capacitance of secondary coil (DRSSTC build )
astralhighway
Wed Mar 18 2020, 11:35AM Print
astralhighway Registered Member #4107 Joined: Sun Sept 25 2011, 07:30PM
Hi all,
I’m looking for approximations of secondary coil self-capacitance. I note that even a few pFs wildly lowers self-resonant frequency.
My secondary has inductance of 27mH (theoretical)
I’m trying to decide whether to stick with a full bridge of 4 x TO-247 devices ( Fairchild FGH75N60UFTU) or use a large toroid and get the operating frequency down to around 120KHz to switch with CM300s.
It will be a lot easier to complete the physical build but has spending implications ... budget creeping !
This is my fourth ever coil , and my second SSTC.
Mon Mar 23 2020, 02:23AM
and for inductance ... Link2
MRMILSTAR
Mon Mar 23 2020, 03:25AM
MRMILSTAR Registered Member #62119 Joined: Sun Feb 04 2018, 04:59AM
JAVATC will give you the self-capacitance and many more parameters.
teravolt
Fri Apr 24 2020, 04:18PM
you may have already found your answer but mesure the inductance at 1khz and then find the resonant frequency and solve for capacitance. as far as a big toride bogger is better because it will become the dominant capacitance and not disributive capacitance, ditributive capacitance is in paralell with your secondary inductance and a toride is series capacitance with secondary inductance witch is what you want.
