Registered Member #61406
I'm trying to isolate parrellel resonance circuit using a transformer, but I'm not sure how to size the transformer, as its inductance is in series with the resonance circuit. Do I have to use phaser diagram with a balanced -j,+j? Just started looking at this aspect so not much information.
Registered Member #2431
youre going to need a simulator and every value of capacitance and inductance and resistance:
Parrallel primary feed of: RLC to primary RLC to secondary RLC to tank
Values for each of the three transformers. RLC to primary 1,2,3 RLC to secondary 1,2,3 RLC to tank 1,2,3
parrallel winding to winding capacitence 1,2,3 series winding to winding capacitence 1,2,3
Cross capacitence from pri to sec 1,2,3 Cross inductance from pri to sec 1,2,3
RL of pri 1,2,3 RL of pri 1,2,3 RL of pri 1,2,3
RC of pri 1,2,3 RC of pri 1,2,3 RC of pri 1,2,3
CL of pri 1,2,3 CL of pri 1,2,3 CL of pri 1,2,3
then:
RL of sec 1,2,3 RL of sec 1,2,3 RL of sec 1,2,3
RC of sec 1,2,3 RC of sec 1,2,3 RC of sec 1,2,3
CL of sec 1,2,3 CL of sec 1,2,3 CL of sec 1,2,3
From what you show it seems that there will be about 200 more iterations and combinations you'll need to have measured values for if you want to predict that circuits behavior.
Registered Member #11591
Luckily transformers are used all the time in resonant circuits in induction heaters to match impedances. If you can ensure all the transformers attached to the LC have the same impedance looking in, and all your LC tanks have the same resonant frequency, you should be able to match them so they behave as one. I would ignore the parasitic components of the transformers if you can ensure the leakage inductance is much less than the transformed inductance of the LC tank and the magnetising inductance much greater.
Thanks, would the LC tanks change with n like L/n and C*n ? Or stay the same LC values. I did try running one with a transformer, but not much power got transferred. So assumed the resonance frequency changed up or down. Not quite sure what to ask, I'll do some more thinking.
Step one, build the LC tank so L1*C1 = L2*C2 = L3*C3 ... If you have the same values exactly, you don't need the transformer. Ignoring resistance, impedance, Z = sqrt(L/C), so calculate all the impedance of the LCs. Choose an impedance for the primaries of all of your transformer (based on the voltage you will be running it at usually). use the formula ((Np/Ns)^2) * Zs = Zp, where Zp is your chosen primary-side impedance, Zs is whatever that particular tank impedance is, and Np and Ns are the primary and secondary turn counts for the transformer to choose your transformer winding ratios. Also ensure that Ns causes the secondary magnetising inductance to be much greater than L.
Not sure what the application is, but remember if you change the magnetic field near any of the inductors, the inductance will change and so will the resonant frequency of that particular tank.
Registered Member #162
Resonating inductors, transformers and capacitors at line voltages can get a little too exciting, especially if not thought through.
I suggest a few options ;
1 use a circuit simulator to test your ideas 2 do a few quick checks for feasibility (peak voltages, currents, power etc.) 3 simulate a similar system for lower voltage, whatever you have physically available (e.g. 12 Vac) 4 build and measure then decide what is was that you forgot in your simulation ;) 5 go to #3 until theory matches practice 6 from the ac supply I recommend Fuse, MOV, Fuse 7 ... and some type of 'emergency off' capability :)
This 'simple' project is actually non-trivial. IF you intend to experiment then what do you envision the transformers to be like ?
This technology was widely used - when I was young
Sorry for the late replied. The transformer was not excaly what you linked to, I'm trying to magically or electrical isolate multiple tanks so the power source doesn't see the muiplte as one tank.
Just got back into this project, but changed it to 50Hz line frequency and got a second hand computer and have installed Ltspice.
