  • Guests: 40
a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
05/09 Coronafix (51)
testing circuit that keeps blowing mosfets
Sat Oct 05 2019, 04:23PM Print
I'm working on a project that occasionally causes me to exceed the current limitations of a mosfet's current (40A). Are there any simple techniques to protect the mosfet from this happening?
I've considered using a variable DC power supply with a fixed maximum current of say 20A. I've thought of using some fastblow fuses, but I don't think they would work fast enough.
Any suggestions?
2Spoons
Sun Oct 06 2019, 09:33AM
IamSmooth wrote ...
This is your best bet. So long as to don't have a lot of C in there too.
Fuses are useless. Fuses are for massive over-current faults, by which time your silicon is already toast.
Adrenaline
Mon Oct 07 2019, 03:14PM
Adrenaline Registered Member #235 Joined: Wed Feb 22 2006, 04:59PM
2Spoons wrote ...
That isn't true. You just have to make sure your I2T of your fuse is less than that of the device you want to protect.
2Spoons
Mon Oct 07 2019, 09:21PM
Adrenaline wrote ...
Try " a lot less" - fuses are not precision devices. The trip current also varies with temperature. Which means using grossly over-rated silicon if you don't want your fuse to pop in normal operation.
An electronic current limiter is a much better option.
Mon Oct 07 2019, 11:11PM
I've looked at the I2t of fuses. If I read the chart correctly, a 20A fast blow has a trip time of about 0.1s if the current is 40A. This is not a lot of time for a semiconductor.
I've decided to get a variable power supply to limit the current during my testing phase.
Adrenaline
Tue Oct 08 2019, 01:09PM
Yes, for this use case using current limiting is the way to do it.
My point was fuses can and do protect silicon, in sort circuit conditions.
Tue Oct 08 2019, 05:40PM
I would use pulse by pulse current limiting if possible. With modern ICs its much easier than in past years, and you can use a loop homemade current transformer or un-ravel the nichrome on a high watt cement resistor. Low power loss through heating either way.
The fuses' slow thermal inertia may cause problems with the ultra low mass semiconductor's high speed inertia.
I have a thread somewhere with about 8 pages of discussion on your very issue.
Current limiting unlike fusing can be used as a diagnostic tool, which surprised me. It can indicate short, open, shoot through under varying loads and saturation with a oscilloscope.
Tue Oct 08 2019, 10:42PM
Patrick, any way you can find that thread and post a link to it here?
Wed Oct 09 2019, 06:45AM
Unfortunately the pics dont work. But the UC 280XX or similar is the key. you dont need to setup the whole circuit. you can spoof everything except transistor gate drive, current limit and timing cycle. in this there was another IC i used that linearly rolled back the duty cycle. cant remember.
Im wishing there were a large cache of pics we could sift through. Im sure there are threads ill never see again. I have 5,400 pics going back 12+ years, theyre on 4 different computers and only 3% or so are cropped and fit for posting on the interwebs.
Wed Oct 09 2019, 09:20PM
IamSmooth wrote ...
Agreed, and it can be similarly revealing to look at I2t numbers for the semiconductors. Or infer it from half-cycle-at-power-frequency specs.
I think 20A circuit breakers in household panels are supposed to conduct 40A for about a minute.
Of course they trip as fast as they can in event of a short circuit (>> 1000 A).
The logarithmic delay-vs-overcurrent charts span many decades, and are not constant I2T.
Can anyone tell us about the time delay control mechanisms? Maybe the answers are on the Internet.
Thermal methods (bimetal parts that move)?
Hydraulic mechanisms (solenoid plungers with viscous damping)?
Decades ago, one brand became notorious for failing to trip under a condition where they needed to trip.
