  • Guests: 11
cbfull (52)
Steve Ward (39)
05/20 Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
Need help with current limiting.
hen918
Fri Jan 08 2016, 01:51PM
Patrick wrote ...
Connected to what value resistor ? I used a voltage divder but I guess at the values.
Connected to a similar circuit described above, like the one in this drawing Link2 remembering pin 9 on the drawing is pin 3 on your IC.
Fri Jan 08 2016, 09:07PM
like this ?
1452287278 2431 FT174221 New
EDIT: Wooooooooooooooooooooooooooooooooooooooooooooooooo ooo yeah
Ive got it working, I put 10k ohms where Hen918 suggested.
4.6uS @ 5.1 volts
14.4uS @ 2.8 volts
Vref = 5.1 volts
It does vary linearly with the turn of the potentiometer. Now I need to pick some exact values, and really get the design formalized for a new etch.
EDIT:
pics
1452295953 2431 FT1630 10
1452295953 2431 FT1630 50
1452295953 2431 FT1630 100
EDIT: It appears when I put 1.3 volts on pin 9 ( ILM/SD ) the PWM pins, both drop to zero. so I guess I don't know what "pulse-by-pulse current limiting" means.
Edit : ill be using the IGBT :
]hgtg7n60a4d.pdf[/file] and switching 170 Vdc through the primary, at no more than 4 amps.
hen918
Sat Jan 09 2016, 11:58AM
The control loop of the current limiting is causing it to drop the pwm to 0: When you apply over one volt, the controller drops the pwm, and keeps dropping it until the current voltage goes below 1 volt. If you are keeping the voltage at 1.3V, the controller will rapidly drop the pulse width all the way to zero until the over current voltage is dropped.
DerAlbi
Sat Jan 09 2016, 02:15PM
Hmmmmh. IGBT @ 170V ?
Supose your 4A is the peak current. If the current was rectangular then you IGBT will have Vcesat(4A)=1.8V. What loss in a Mosfet equates to 450mOhm Rsdon. This is quite bad.
If you assume a triangular current waveform the Mosfet is even better due to quadratic dependence on the current instead of nearly linear like the IGBT.
Looking at Digikey, Searching for Single Mosfets, "Vds>200V", "Ids>6A", "Rsdon < 400mOhm" and "THT" then entering the quantity of "1" and sorting for price you get a variety of alternatives that seem so much more suited for your project.....
I case you cant follow my parametric search, then i just name a few:
FQP19N20C (94ct, 170mOhm, 200V, 19A, TO220)
RCX200N20 (110ct, 130mOhm, 200V, 20A, TO220)
FDP18N20F (114ct, 145mOhm, 200V, 18A, TO220)
STF20N20 (120ct, 125mOhm, 200V, 18A, TO220)
FDP39N20 (132ct, 66mOhm, 200V, 39A, TO220)
FDP33N25 (144ct, 94mOhm, 250V, 33A, To220)
..List continues. I just picked the ones that are much more better than your IGBT. (since i only searched for Rsdon<450mOhm.. should have searched for Rsdon<150mOhm)
Sat Jan 09 2016, 06:32PM
DerAlbi wrote ...
I figured someone would say this. smile I just used the 7 amp and 30 amp versions since I have 30 of one and 40 of the other. there is a really good MOSFET I used at 30 volts and less. Which eventually this power supply will work off of at 12-18 volts input at 20+ amps.
EDIT: The voltage varies linearly from 0 - 0.7 after .7 it jumps to 1.25 V. below the .7 the PWM is off entirely. above the 1.25 its on.
I also have to keep the pin 9 below 5 volts or it will blow out.
Sun Jan 10 2016, 09:43PM
I'm moving on to optical feedback of the regulated voltage crossing the isolation barrier. I need to show you guys some PDF's.
PC911L0YSZ - - >
PS2561-1 - - >
SFH6345 - - >
HCPL 7520 - - >
DerAlbi
Mon Jan 11 2016, 12:42AM
For an analog loop you should avoid PushPull-Outputstages like the PC911L0YSZ. Easy solutions like the PS2561-1 is fine. You could try it with SFH6345 , but i dont see much reason there. HCPL7520 is surely interesting.. but i honestly think its overkill.
Mon Jan 11 2016, 01:00AM
Here's the PDF's . . . still considering what DerAlbi has said.
Ive seen those analog loops a thousand times, but don't know how to design one. I did talk to Uzzors a while ago, he said they were easy.
DerAlbi
Mon Jan 11 2016, 01:20AM
Actually they are quite complex if you want to get them right. It is however easy to get something working. It depends on what kind of control loop you want to implement. If its kind of digital like "start switching" when voltage is low or "stop switchting" when voltage is high enough then its easy. but its most likely inefficient, produces high ripple under constant load conditions and... yeah.. its basically nothing else than a most primitive over voltage protection.
A real analog loop also controls how much energy is transfered when switching. Such a loop can be too slow to be optimal, produce overshoots if too fast or it even can oscillate.
Its in no way trivial, but often it just works somehow (most likely when its made really slow). As long as you dont care to make it optimal, its can be easy.
Thats why i propose the PS2561-1.
The Push-Pull-Output has too much loop-gain (making it digital oscillating). The SFH6345 just adds complexity to the loop and the HCPL7520 might even have not enough gain. Just try.
Mon Jan 11 2016, 01:50AM
Ok I, looking for shcematics then. I don't know if I need a voltage reference or not. or if a zener will work.
1452491448 2431 FT1630 S2009724972776
Keep in mind I don't know anything about poles or zeros. I don't have a TL431 either.
]tnd381-d.pdf[/file]
