  • Guests: 20
a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
05/09 Coronafix (51)
Electrical connection to a Tungsten rod
Signification
Tue Jul 02 2019, 06:04AM Print
I have a 3/8" x 2" Tungsten rod and would like a high current "permanent" connection (Large Cu wire, etc. on the far/cooler) end...any ideas for this permanently connected electrode?
Wed Jul 03 2019, 11:59AM
I've successfully used the brass inserts with two screws that you find in 'chocolate block# electrical terminal strips
e.g. Link2
Signification
Fri Jul 05 2019, 11:03AM
@Sula...
Thanks for the tip. It looks like the 60A connector may work! One thing I am worried about: Since Tungsten is said to be so brittle (one of mine is only 1" long, 3/8" diameter, and 70%W / 30%Cu), and the clamp-down on the rod is not completely circular when tightened (by the screw), do you think the un-even clamp will possibly result in chipping/cracking if tightened enough to carry the full 60A?
hen918
Fri Jul 05 2019, 01:40PM
I doubt it; the brass terminal is soft enough to deform and reduce the point load on the tungsten.
MRMILSTAR
Fri Jul 05 2019, 03:04PM
MRMILSTAR Registered Member #62119 Joined: Sun Feb 04 2018, 04:59AM
With a drill and a band saw you can make your own custom clamps that are guaranteed to fit. I have made several out of aluminum but you could also use brass.
Signification
Sun Jul 07 2019, 03:51PM
Also, I have a friend who likes guns. Since 3/8" is close to 9mm, I asked for a spent brass casing--It was a tiny bit too small to insert the rod. Now I need to try a .38" since that is a wee bit larger. So far I can't find one. Does a .38 mean 0.38"? Thanks all...
2Spoons
Tue Jul 09 2019, 12:06AM
"A tiny bit too small" sounds ideal. Flare the opening, then force the shell onto the rod with a hammer. perfect friction fit.
You can probably buy 3/8" brass tube at a model shop, and use the same trick.
Tue Jul 09 2019, 08:09AM
Brass has about 4x the linear coeficient of thermal expansion of tungsten,
so a push-fit may fail.
Ash Small
Mon Jul 15 2019, 10:12PM
Something that mabe worth looking at is copper or brass fuel, gas or water pipe fittings. Fuel/ gas pipe is avainable in 3/8", water pipe compression fittings are available in 10mm as well as Imperial/American sizes. You may need some copper foil or similar as a shim, but I'd look at what's available locally.
Tue Jul 16 2019, 12:24AM
The electrical connection of course needs to be good because of the high current.
If the spark gap is expected to be used at high current for a continuous period then cooling of the electrodes becomes vital also,
at least a fan-cooled heatsink, or a large heat spreader, for each electrode
preferably with air blasting through the gap.
Overall, a high current spark gap is a very noisy component.
