Electrical connection to a Tungsten rod
Signification, Tue Jul 02 2019, 06:04AM
I have a 3/8" x 2" Tungsten rod and would like a high current "permanent" connection (Large Cu wire, etc. on the far/cooler) end...any ideas for this permanently connected electrode?
Sulaiman, Wed Jul 03 2019, 11:59AM
I've successfully used the brass inserts with two screws that you find in 'chocolate block# electrical terminal strips
e.g.
Re: Electrical connection to a Tungsten rod
Signification, Fri Jul 05 2019, 11:03AM
@Sula...
Thanks for the tip. It looks like the 60A connector may work! One thing I am worried about: Since Tungsten is said to be so brittle (one of mine is only 1" long, 3/8" diameter, and 70%W / 30%Cu), and the clamp-down on the rod is not completely circular when tightened (by the screw), do you think the un-even clamp will possibly result in chipping/cracking if tightened enough to carry the full 60A?
hen918, Fri Jul 05 2019, 01:40PM
I doubt it; the brass terminal is soft enough to deform and reduce the point load on the tungsten.
MRMILSTAR, Fri Jul 05 2019, 03:04PM
With a drill and a band saw you can make your own custom clamps that are guaranteed to fit. I have made several out of aluminum but you could also use brass.
Signification, Sun Jul 07 2019, 03:51PM
Also, I have a friend who likes guns. Since 3/8" is close to 9mm, I asked for a spent brass casing--It was a tiny bit too small to insert the rod. Now I need to try a .38" since that is a wee bit larger. So far I can't find one. Does a .38 mean 0.38"? Thanks all...
2Spoons, Tue Jul 09 2019, 12:06AM
"A tiny bit too small" sounds ideal. Flare the opening, then force the shell onto the rod with a hammer. perfect friction fit.
You can probably buy 3/8" brass tube at a model shop, and use the same trick.
Sulaiman, Tue Jul 09 2019, 08:09AM
Brass has about 4x the linear coeficient of thermal expansion of tungsten,
so a push-fit may fail.
Ash Small, Mon Jul 15 2019, 10:12PM
Something that mabe worth looking at is copper or brass fuel, gas or water pipe fittings. Fuel/ gas pipe is avainable in 3/8", water pipe compression fittings are available in 10mm as well as Imperial/American sizes. You may need some copper foil or similar as a shim, but I'd look at what's available locally.
Sulaiman, Tue Jul 16 2019, 12:24AM
The electrical connection of course needs to be good because of the high current.
If the spark gap is expected to be used at high current for a continuous period then cooling of the electrodes becomes vital also,
at least a fan-cooled heatsink, or a large heat spreader, for each electrode
preferably with air blasting through the gap.
Overall, a high current spark gap is a very noisy component.
radiotech, Wed Jul 17 2019, 10:30PM
Could you treat the rod in an induction heater field inside a Pyrex flask
filled with hydrogen ?
The Chinese modules are cheap, and someone her hacked an induction cooktop a while ago.
Could this 'sintering' make your rod more ductile.
And do protect against the hydrogen blowing the flask to smithereens if it goes wrong.
2Spoons, Thu Jul 18 2019, 02:00AM
radiotech wrote ...
Thats more likely to have the opposite effect and make it brittle.
