  • Guests: 28
Adam Munich (30)
Alfredo Texacca (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
New Topology
The Lightning Stalker
Sat Mar 16 2019, 05:19AM Print
The Lightning Stalker Registered Member #4230 Joined: Sat Nov 26 2011, 05:50AM
I don't have anywhere else currently to release this so I'm putting it here. This is still just a preliminary drawing and has not been tested.
Sat Mar 16 2019, 05:25AM
Of course the image uploading is broken.
Sat Mar 16 2019, 05:26AM
Ok try this
H5jSQLp
Hazmatt_(The Underdog)
Sat Mar 16 2019, 04:08PM
You need to add an oscillator to the input, the oscillator is not going to self-start, and Ctank needs to go away, or go in parallel to the primary.
Patrick Konesky
Sun Mar 17 2019, 04:27AM
Patrick Konesky Registered Member #65366 Joined: Mon Oct 08 2018, 05:01AM
Isn’t that a current sense transformer? It might oscillate but with a bad phase shift.
Sun Mar 17 2019, 09:53PM
It's the base return of his coil primary that he's using as feedback to steer the oscillator, but at turn-on there is no feedback.
Tue Mar 19 2019, 09:02AM
The pot and resistor are there to provide startup bias.
hen918
Tue Mar 19 2019, 04:37PM
As far as I can see the phase between input and output is inverted, i.e. the dots need to be the other way, and I'm not sure the dv/dt of the turn on will be enough to kick the input the other way to start the oscillation.
Wed Mar 20 2019, 08:01AM
The N/P follower is non-inverting, so it should be in phase.
2Spoons
Wed Mar 20 2019, 09:12PM
I would have thought you need more gain in the loop to ensure oscillation. Also what are you doing with that 2n2222 at the bottom of the bias chain? Is that meant to be a constant current bias? Because thats a horribly unstable way to do that - depends heavily on the transistor gain and temperature. You would be better off with just a resistor.
Also startup is more likely if you were to bias your follower into class AB.
