  • Guests: 29
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
An attempt at building a SLR inverter
ritaismyconscience
Sat Mar 16 2019, 05:02AM Print
ritaismyconscience Registered Member #62937 Joined: Wed Jun 06 2018, 08:20PM
My inverter seems to have killed the flyback. Also, it seems like I need a better core (and maybe a transformer without a diode) because this one seems to be saturating (the circuit pulls 25A at its peak).
ritaismyconscience
Sat Mar 16 2019, 05:21AM
Sorry for double posting, but editing doesn't work on my computer.
Here's the link: Link2
ritaismyconscience
Sun Apr 14 2019, 06:05AM
Update: I got a transformer from a microwave and I used it. Now it works much better. I can only run it off 50VAC because if I go any higher, it arcs over the safety gap (this thing is only designed for 2kV) and it spits steel sparks all over the place.
Waveform when shorted: Link2
Video of it working: Link2,dur,ei,expire,id,ip,ipbits,itag,lmt,mime,mm,mn,ms ,mv,pl,requiressl,sc,source,susc& signature=646010E3EA9F255914E2EAAFEF4BFF551CB9EDAE .213DD6871996F11E23342361B105400A82987D98& key=cms1&redirect_counter=1&cm2rm=sn-n4vll7s& req_id=500613f9f1ffa3ee&cms_redirect=yes&mm=34& mn=sn-a5mlrnes&ms=ltu&mt=1555221696&mv=m
C=4.8uF, leakage = 16.5uH
Mon Apr 15 2019, 03:53AM
in my experience external secondaries are undesirable and the cylinder type flybacks seem to do poorly, presumably the diode as you said.
johnf
Mon Apr 15 2019, 09:48AM
Why would anyone pull an arc off a flyback inverter
with poor leakage inductance
all the arc energy is reflected back into the primary driver with excessive voltage transients (caused by the leakage inductance).
Arcs cause high dV/dt and high dI\dt both very destructive to solid state electronics
ritaismyconscience
Tue Apr 16 2019, 07:08PM
I'm using a full bridge.
