  • Guests: 32
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
Series IGBT/mosfet HV "spark gap" / OLTC topology
swordfish
Tue Jul 24 2018, 03:38AM Print
swordfish Registered Member #3218 Joined: Mon Sept 20 2010, 10:42AM
Hi All,
I recently came across the attached papers which detail some options for running mosfets in series for high-voltage switching. I'm wondering if IGBTs could be used with these topologies to make a direct, solid state replacement for conventional SGTCs? It would be a bit like the SISG concept detailed by Terry years ago but would allow active break rate control. Essentially an OLTC but using a HV transformer and capacitor to improve power capability. Any thoughts?
Cheers,
Greg
]series_mosfet_power_supply.pdf[/file]
]series_mosfet_switching.pdf[/file]
Tue Jul 24 2018, 04:02AM
There have been discussions and a couple of attempts by members here and others,
I can't remember much other than it is non-trivial.
Google should find most of the work done.
EDIT: I just had a quick google but could not find much myself,
I hope your google-foo is better than my memory.
swordfish
Tue Jul 24 2018, 04:53AM
My google skills aren't much better. I see Finn hammer has some kind of triggered SISG but can't find any details...
