  • Guests: 18
Colin 99 (53)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
Raspberry pi interupter
Gordon
Tue Jul 17 2018, 11:15AM Print
Gordon Registered Member #61983 Joined: Fri Dec 08 2017, 12:07AM
Morning,
Has anyone tried or thought about using a raspberry pi as an interupter or midi pwm for a coil yet? Of course using fiber optics to isolate it at a good distance. I am new to the raspberry pi and still learning it's capabilities which seem like it has a ton of potential for experimenting with a coil. Any thoughts or ideas?
Bjørn
Tue Jul 17 2018, 01:25PM
In theory it should work fine, but the documentation is not very good. Accurate timing means you have to use hardware peripherals that can be tricky to use.
What model do you have?
Gordon
Tue Jul 17 2018, 02:38PM
Raspberry pi 3 b+
