  • Guests: 26
a.gutzeit (63)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
Preparing High Voltage Oil.
Sat Aug 25 2018, 06:25PM
Canola oil clear for transform and caps, and clear olive oil for instruments like high frequency probes.
johnf
Sun Aug 26 2018, 04:49AM
Why not go to shell and buy some Diala high voltage oil
Here in NZ I pay US$0.75 per liter for it in 20 liter lots
Sun Aug 26 2018, 05:48PM
yes but i dont want hydrocarbon oil, and for our purposes i find little difference in oils so long as they dont have a green clorophyll color left in them. Dont use corn oil. it turns to garbage in a few weeks.
Many HV companies are moving to soy bean oil for 20 gal to 300 gal tank transformers.
20 liters is quite a large volume what do you use it for ?
johnf
Sun Aug 26 2018, 07:55PM
It is used in my SEM high voltage tank (70kV)
vircator
Tue Aug 28 2018, 08:46AM
vircator Registered Member #3217 Joined: Mon Sept 20 2010, 06:14AM
Thank you for pointing me to Diala johnf. I found a local supplier. It's cheeper than many food oils and is specifically designed for HV applications and has good aging properties.
Nickel
Mon Feb 04 2019, 10:00AM
Nickel Registered Member #4367 Joined: Thu Jan 26 2012, 07:54PM
For the vacuum pump, a cheap experiment would be to connect two old scrap refrigerator compressors in sequence. This can get you quite a low absolute pressure at minimum cost, before you commit $zillions to a professional unit.
(We use them on my local miniature railway to provide vacuum to operate switches and points remotely.)
Tue Feb 05 2019, 05:58AM
it was 59$ for the pump, $40 for the plumbing, with zero risk of leaks from brazing, and contamination from refrigerant im happy. besides i make a lot of carbon fiber.
