  • Guests: 18
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
Distribution transformer pulsing
Afrodita
Fri Nov 17 2017, 05:33PM Print
Afrodita Registered Member #4092 Joined: Mon Sept 12 2011, 06:59AM
My 11kV distribution transformer pulses and I cannot determine the cause. The control unit consists of a 35Amp Variac with a variable inductor from an arc welder in line with it. The inductor is before the variac.
The sparks generated by my 8-inch coil are purple and weak. At 200 volts input I am only getting 3ft sparks.
hen918
Fri Nov 17 2017, 05:57PM
A circuit diagram, pictures or even a description would help!
