  • Guests: 18
Colin 99 (53)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
Inductor the circuit, higher voltage and current over a shorter time
Plasma
Sun Oct 08 2017, 03:11AM Print
Plasma Registered Member #61406 Joined: Thu Jan 05 2017, 11:31PM
Hi I've changed the tack from a capacitor to a inductor.
I've got a 12volt source going through a 4ohm resistor, then to a 1henery inductor. I plan to charge it up to a value then return the energy into a circuit, I would like a high voltage than twelve and more current than three but over a shorter time frame depending on how much current and voltage is produced.
How would a circuit look like and a explain it, as I'm sure about buck boost.
I've simulated change 4 ohms to 10k ohms, it makes a high voltage but I can't seem to extract much power
Thanks
Sun Oct 08 2017, 05:56AM
Plasma
Sun Oct 08 2017, 06:23AM
Yeah I came to that conclusion as well, but if I have a 1ohm switch, and then close it over a 1ohm load, it should double the voltage (good), but the current will be less.
I'm trying to work out how to trade time for volts and current but still in the 90% joules range
