  • Guests: 20
ramses (16)
Arcstarter (31)
Zak (15)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
Ruhmkorff induction coil
StaticBuildup
Sat Sept 30 2017, 05:28PM Print
StaticBuildup Registered Member #61695 Joined: Sun Jul 16 2017, 11:22PM
Hi everyone, I have been having some problems with an induction coil and wonder if someone here could help.
This is the coil:
The problem is that it only produces very small arcs (the video is about as good as it gets, they are usually about 2mm). The interrupter often stops after a few seconds and needs a push to start again. It only occasionally works well.
The other induction coils that I have are much more lively. They are meant to be lower voltage, so not much spark, but they are much more reliable and the spring action of the interrupter is much better.
I have measured the resistance of the primary and secondary and they are 0.6ohms and 7.56k. The capacitor in the base is 1uf and I measured it and it is close to that. I have cleaned the contacts and adjusted the interrupter gap.
Nothing is noticeably overheating. The current draw at 6V is about 1A, when it is working reasonably well.
Anyone here got any experience with these coils?
johnf
Sat Sept 30 2017, 06:47PM
Most probably a shorted turn
caused by green spot on the secondary or
some one over volting the primary
or trying to get the spark to jump over to grat a distance causing the insulation to break down
A "Q" meter may help to see if the secondary is ok
StaticBuildup
Sun Oct 01 2017, 04:20PM
Hi John, thanks for replying. I guess that it would be very difficult to repair a shorted turn. frown
I don't have a Q meter, but I will ask around in case someone I know has one. Is an LCR meter similar?
johnf
Sun Oct 01 2017, 06:18PM
Some LCR meters also give Q
measure inductance of both primay and csecondary then again with not measured winding shorted
This measures coupling factor so a very big change in inductance with the winding shorted tends to say that the winding is ok
the expected ratio should be a change of 80-100 times change with the inductance much less with the other winding shorted
StaticBuildup
Sun Oct 08 2017, 10:28PM
Ok thanks, I will try that if I get a meter.
Wed Oct 11 2017, 02:37PM
"I have measured the resistance of the primary and secondary and they are 0.6ohms and 7.56k." - These figures strongly suggest that your induction coil is a re-purposed automotive ignition coil!
I would guess that the most likely reason for poor performance was in the erratic nature of the contact breaker as you describe it. Clean the contacts with very fine abrasive paper.
Try wiring a 100nF 350V capacitor across the contacts and see if that perks it up. If it does, try a 200nF, then the next size up if the 200nF shows improvement over the 100nF. As well as suppressing wasteful and destructive arcing, the capacitor can help boost the coil output by creating a resonant LC circuit with the coil windings.
StaticBuildup
Thu Oct 12 2017, 11:10PM
Thanks for the help. I didn't know that some of those coils were made from automotive ignition coils!
I have cleaned the contacts. I will try to find some capacitors and see if that improves it. There is definitely arcing on the contacts, sometimes more than from the output!
