Registered Member #96
Hi,
Just occurs to me that as many folks have low power tubes in their spares boxes, making a basic voltage limited current cutoff charger should be trivial in a SHTF extreme Carrington event/EMP scenario.
Li-ions should still work fine but worst case the protection circuitry will be history depending what hit it. Usually the fuse goes so the cell inside will still be OK if a way could be found to charge them.
Registered Member #162
After your "SHTF extreme Carrington event/EMP scenario" one of my least significant concerns will be cell-balancing and what are you expecting to power with your fully charged and balanced lithium batteries ?
Even now, for a lot of my diy stuff I use cells from dead laptop battery packs, I charge them individually then use them as a pack ... tedious, but no problems so far.
Registered Member #11591
Sulaiman wrote ...
I designed and only half built so far (I meant to do it this summer) a complete standalone, microcontrolled 18650 laptop battery analyser with two channels and an SD card slot to store the results on. It will do a number of charge - discharge cycles logging the voltage and current every second. This will then be graphed or used in a program I have yet to write that automatically searches a database of tested batteries to find the perfect matches for putting them into packs.
A simple solar shunt regulator would be fine. With most Li-ion regulating them to 3.97V will store 95% charge and extend life considerably, though one circuit will be needed per cell. For something like a device able to keep freezers running you'd need a large solar panel and a UPS, though there are ways around that. I found on one of the amateur radio sites a basic Royer circuit based on two tubes (eg 833A, other power triodes also work) which can be used in multimode to either get maximum power for radio or high power low frequency for mains power.
Registered Member #43481
A P/N junction does not a diode make. Check it yourself with an ohmmeter. Measure the forward and reverse resistance of a solar cell with the active surface of the solar cell blacked out.
Registered Member #543
EBF83 - a double diode pentode - was designed to operate happily with as little as 6V on the anode in car radio applications.
Two Lion cells such as 18650 in series are all that is needed for anode voltage for EBF83 and its car radio valve kin such as nifty double triode ECC86.
