  • Guests: 15
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
Optic fiber receivers
wikus
Fri Mar 24 2017, 09:50PM Print
wikus Registered Member #58198 Joined: Sun Dec 27 2015, 11:15AM
Hi all I need some advice. I cant get a OPF 2412 T fiber receiver in my country but found a OPF 2416 T(OPTEK). IT looks like it is an AC receiver.
Can I use this or not ,and if I can will somebody help me with a circuit .
I looked at the datasheet but it makes no sense to me .
Thanks all help will be appreciated
]opf2416t_2bbdb1475c.pdf[/file]
dexter
Fri Mar 24 2017, 11:21PM
check this out: Link2
in my case i got an OPF 2414 and with the circuit from the link above it works (at least on the bench) and i think it will work for you also
i replaced the voltage divider from comparator "-" input with a trim pot for better adjustment of the threshold voltage
