  • Guests: 24
Alexandre (32)
05/05 Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
After a high temperature electrical insulation
Plasma
Mon Feb 06 2017, 07:15AM Print
Plasma Registered Member #61406 Joined: Thu Jan 05 2017, 11:31PM
Hi for a project I'm working on I would like some material the would be a pipe, that can withstand flame temperature for about 2 seconds, and is a electrical insulator.
I plan to burn some gas in the pipe and have it travel through to the other end.
Hoping someone has a idea what I could use.
Mon Feb 06 2017, 10:37AM
almost any engineering material will withstand 2 seconds of flame,
pressure/rupture considerations are probably more important,
can you give more details?
Plasma
Mon Feb 06 2017, 04:24PM
The coil will be about 0.5 meters diameter with about 10 turns.
Natural gas and compressed air will be mixed in a steel type chamber to hopefully achieve a flame front at 100m/sec around the tube, then vented into atmosphere.
I plan to have 10 spark gap spaced around the coil to discharge 9kv capacitor bank.
Side thing, was going to run a copper wire next to the tube to measure the voltage.
Mon Feb 06 2017, 06:56PM
maybe ceramic, porcelain or glass. I dont think an organic material will survive what you describe. Even then cracking maybe an issue.
Tue Feb 07 2017, 08:38AM
how about hose pipe ?
clear pvc tubing to see the flame ?
Plasma
Tue Feb 07 2017, 12:51PM
I like the idea of see through tube, even temporary, I should be able to see how far it travels.
Should be able to gauge if it will survive higher temperature at lower temperature and velocity during testing.
radiotech
Sun Feb 12 2017, 01:09AM
You need to know if the material you choose becomes a conductor when heated,
lest you make a Nernst Glower.
