  • Guests: 17
Matthew T. (35)
Amrit Deshmukh (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Metallic hydrogen :-)
Thu Feb 02 2017, 06:18AM Print
Finally, took 495 GPa but Harvard may have done it.
Seems to be metastable, the catch is that to make that one precious Nobel-worthy sample was at the cost
of literally hundreds of failed attempts and broken diamonds.
On the flip side the procedure is well documented and can be possibly done at lower pressures using
silicon carbide modified in a similar way at low temperature with LiH6.
Intriguingly Link2 suggests that MH may actually
have existed in used (defunct) NiMH batteries and all this time been shielded from us by the nickel
casing. If they overcharge and vent the MH is lost but at least this means that waste EV packs
could be a valuable source of MH if reprocessed correctly.
Thu Feb 02 2017, 08:45PM
lets scoop some out of Jupiter.
Physikfan
Fri Feb 03 2017, 08:01AM
Physikfan Registered Member #60240 Joined: Mon May 16 2016, 07:01PM
Hi Conundrum
Do you know the story of cold fusion by electrochemistry?
Sun Feb 12 2017, 07:03AM
Ages ago. Also it appears that MH though metastable is not stable in air at ambient pressure or even a hydrogen atmosphere at room temperature. It needs cooling and pressure or it becomes a gas again.
also see Link2 related maybe?
Methinks they should rewrite the Periodic Table for high pressure.
Sad news folks, Link2
On the flip side they *did* apparently see signs of diamagnetism but the data was very sketchy.
