Metallic hydrogen
Conundrum, Thu Feb 02 2017, 06:18AM
Finally, took 495 GPa but Harvard may have done it.
Seems to be metastable, the catch is that to make that one precious Nobel-worthy sample was at the cost
of literally hundreds of failed attempts and broken diamonds.
On the flip side the procedure is well documented and can be possibly done at lower pressures using
silicon carbide modified in a similar way at low temperature with LiH6.
Intriguingly
suggests that MH may actually
have existed in used (defunct) NiMH batteries and all this time been shielded from us by the nickel
casing. If they overcharge and vent the MH is lost but at least this means that waste EV packs
could be a valuable source of MH if reprocessed correctly.
Metallic hydrogen
Patrick, Thu Feb 02 2017, 08:45PM
lets scoop some out of Jupiter.
Metallic hydrogen
Physikfan, Fri Feb 03 2017, 08:01AM
Hi Conundrum
Do you know the story of cold fusion by electrochemistry?
Metallic hydrogen
Conundrum, Sun Feb 12 2017, 07:03AM
Ages ago. Also it appears that MH though metastable is not stable in air at ambient pressure or even a hydrogen atmosphere at room temperature. It needs cooling and pressure or it becomes a gas again.
also see
related maybe?
Methinks they should rewrite the Periodic Table for high pressure.
Sad news folks,
On the flip side they *did* apparently see signs of diamagnetism but the data was very sketchy.
