Electrostatic demonstration: pin wheel
Physikfan
Sat Aug 20 2016, 05:21PM
Registered Member #60240
Hi
A four-pronged pin wheel is connected to a kV source:
Charge is transferred to the pin wheel and is sprayed into the air and produce clouds of ions. As charges of the same sign repell each other the clouds of ions in the air repell each pronge. The wheel starts to rotate. The rotational speed increases with the applied voltage.
Regards
Physikfan
Antonio
Registered Member #834
A different version:
kimbomba
Registered Member #3854
Very nice setup Antonio. Your channel deserves much more subscribers.
Physikfan
Hi Antonio
Great interesting and impressive experiment
Regards
Physikfan
Robert Clark
Registered Member #58454
Very well done. These work on the principle on electrohydrodynamic propulsion(EHD). We may be getting close to having such craft fly independently without attached wires:
Bob Clark
