  • Guests: 19
kg7bz (68)
steve516 (31)
05/17 Finn Hammer (72)
05/17 Blue Adept (43)
05/17 Nickel (68)
Need help with current limiting.
Wed Dec 09 2015, 06:32AM
Ive been laying out the circuit board for etching. the IC is in the SOIC-16 package. So ill solder the IC on the trace side, and the other components on the top side. I'm going to use 2 of the TO-247 transistor I have and for now, the transformer will be external, just held in place with short but heavy wire by its primary. The transformer is experimental and may need to be re-wound until I'm happy with it.
Sat Dec 12 2015, 06:29AM
Progress.
1449901791 2431 FT174221 Etch2
You can see a large blank space at the bottom, that's for hot gluing the current transformer, which will no doubt be re-wound several times.
Some of the traces are pretty bad, so ill etch a few more boards, but I'm looking into ExpressPCB. In any case, ive got colored wire and all the components. so tomorrow ill be populating the board and getting my 13.8 battery replacer and ATX power supplies ready. The SOIC-16 etched section came out perfect.
Electra
Sat Dec 12 2015, 11:55PM
I don't think you'll need to rewind the current transformer that many times, the secondary voltage is developed across a load (burden) resister and its that resistance and turns ratio that determine the secondary voltage. Or even use a combination of fixed and variable resistors if you need adjustment.
I sec (A) = I pri x(Np/Ns)
You can buy ready made ones to save fiddly winding in standard ratios 1:200 etc. Which look epoxied more like a sensor, Note watch out some are only for line frequency 50/60hz.
Sun Dec 13 2015, 07:21PM
Electra wrote ...
Yes I looked at these too, but I need to learn the lesson of making them. I'm thinking of using 1 turn of each primary, through the ferrite core. then 10 or so secondary turns I guess? then use a voltage divider with minor pot for minor tuning.
Wed Dec 16 2015, 12:26AM
EDIT : its been a long night.
Ill need others like Goodchild to chime in again. I'm unsure how to replace the sense resistor, with the current transformer. I don't know how to put the signal into the IC.
-I already have the signal diode bridge and burden resistor on the board, I just don't know where to send that signal.
-I need to set the oscillator frequency to 75 kHz, don't know how. (the Rt and Ct pins I think)
-I need the current transformer input resolved.
-I think I have the voltage regulation solved with a voltage divider.
- I'm not sure of the ramp pins use or purpose. there was a unitrode/TI pdf that explained this but I cant find it.
I'm trying to figure out my RC time constant for 13us (75kHz) using a 100pF film cap. [100pF and 133kohms I think.)
1450248775 2431 FT1630 Uc Ccm
It does say so in this pin list.
1450245529 2431 FT1630 Cmc5
1450245529 2431 FT1630 Cmc6
3D printed mount for the core.
1450245529 2431 FT1630 E Cores
Ok here we go :
1450225570 2431 FT174221 Cmc1
I'm hoping I counter-wound the CT right.
1450245177 2431 FT1630 Cmc2
1450245177 2431 FT1630 Cmc3
1450245177 2431 FT1630 Cmc4
1450249908 2431 FT1630 Mystery
Ive outlined the mystery components in red.
MEhhehsfdg ee eeee . . . eyes are blurry, time for bed soon. .ew.d.dc. mehhh
Electra
Thu Dec 17 2015, 12:40AM
What's going on there is, their using the current feedback from the sensor resistor or transformer as the ramp input. A part of the ramp voltage from across timing capacitor is ac coupled through the 10nf cap ( probably for compensation ) and reduced through the potential divider formed by the 8.2k and the 1k resistors. The two ramps effectively add at the ramp input pin.
This mode of current control rely's on having an inductor on the output of the transformer for it to work.
You could replace the sense resistor with the burden resistor I think?
An app note that gives a little more insight into the theory, though mainly in respect to buck or boost converters. :- Link2
Edit,
looks like the 120pf cap plays more of a part in the voltage ramp feed, its reactance is lower than the 8.2k resistor.
Anyway hope I've got the general idea right.
Thu Dec 17 2015, 03:13AM
it keeps sparking when I put power in. I may have killed the IC.
Electra . . . if its that red bit is so complicated I may never get it to work, but ill keep trying.
I don't know what to change from their 1.5 Mhz example, to my 75kHz design. I'm going to read your PDF and re-read the TI/Unitrode PDF's.
EDIT: no matter what I do the IC power pins say 0 ohms, so the traces or other components must have a short.
EDIT: Spark problem solved, a wee bit of wire insulation was missing, in a very small spot.
EDIT: the refercne voltage of 5.1 V is working.
EDIT: the ramp is working, but its at 12kHz. ill need to get it to 75kHz
1450327785 2431 FT1630 Osc1
EDIT: ive got the ramp working at 1.5V and 14uS. ( 70kHz, close enough ). I don't see anything on the gate drive pins though.
Link2 pdf. . . .
Link2 . . .
EDIT: ill need a snubber for the turn on spike of the CT's leading edge.
1450331828 2431 FT1630 Spike
1450331828 2431 FT1630 Pulse
1450337362 2431 FT1630 Ilm Pin
I'm operating under the assumption that this pic shows these two comparators working as such; below 1 volt the PWM is unmodified, between 1 and 1.4 volts the PWM is clipped back, as soon as 1.4 volts is hit, the transistors are off entirely.
(or that 0.4 V difference is hysteresis) Sigh this is hard. . .
Electra
Thu Dec 17 2015, 09:40PM
Ok maybe simpler to get it working in voltage mode control first, if you connect pins 6+7 together and to top end of cap CT, (hope that works with this ic). The current transformers burden resistor now just goes to pin 9 via a 1k, and if you include the cap. Like you have it in your app note fig 11.
The two comparators, I'm also a little puzzled by the second one. As the first one at 1v, is pretty straightforward it terminates that cycle regardless of where the PWM is if the output from the current sensor exceeds the 1v threshold. I would have thought that would have done the trick and prevented the current increasing further because now both mosfets ore off.
Now how does it manage to get to 1.4v? delay in the current sense path (your c to filter out the leading edge) or maybe something really bad has happened transformer saturated, and the current rises so fast in one half cycle, that the switching devices cannot turn off fast enough to prevent the increase.
When this does happen though, looks from the block diagram it restarts the error amp what's the reason for this, I'm not too sure possibly it restarts the PWM from zero again.
So under 1v unmodified as you say, Cut back at 1v, don't know if it means if anything happens in between but at 1.4v it shuts down the error amp.
Fri Dec 18 2015, 02:23AM
Id like to put in bogus signals, then measure the PWM response. I don't know how the RAMP pin figures in. I start with the input between ILM/SD and PGND to see what happens I guess.
Electra
Fri Dec 18 2015, 07:09PM
Don't know what you call bogus signals, If you mean want to run it open loop there's a test circuit for that in the data sheet, you have to set up the op-amp part, simple dc feedback just treat it as any ordinary op-amp ( pins 1,2,3). Turn a pot and see the pwm waveform change.
PWM works by comparing sawtooth wave (that's your ramp input pin) and a control voltage (the output from the op-anp part) using a comparator. At the start of each cycle a latch is set turning the output high, soon as the ramp exceeds the dc level of the control voltage the comparator changes state re-setting the latch, the outputs go low. So increasing the control voltage increases the duty cycle.
