  • Guests: 65
RateReducer (35)
11/01 RateReducer (35)
11/02 Download (31)
11/02 ScottH (37)
Need help with current limiting.
Tue Jan 09 2018, 01:40AM
hen918 wrote ...
Where are you getting the 12V from? if it's on your input side you'll loose all isolation, and if it's on the output, what guarantees it's at 12V?
Yes i considered this witch is why i always want to post and get opinions. But i was thinking when the conventional secondary is unpowered the LED is dark, with this circuit the 12 or Vreg should be dark too, until start up, then the control segment brightens and reduces the control error signal. but i guess the LED current is dependent on whether its 12v is even present.
ok, back to simple TL431, with the shown OPTO, we can revisit this issue in a future version.
Im looking at that app note for what applies to my circuit, seems useful, though its for a Phase shifter.
Thu Jan 18 2018, 05:57AM
Link2 SMPS for ATX power supply.
Link2 Another schematic.
Link2 PFC + SMPS schematic.
1516265843 2431 FT1630 Line 120
Heres the front end ive drawn so far, i meant to include te inrush current limiter... ill repost that change.
UPDATE:
logic and control
1516326116 2431 FT1630 Logic And Control
UPDATE :
the board will be 3.8 x 6.75 or smaller, im sending it out to a board shop.
Plasma
Fri Jan 19 2018, 08:11PM
Patrick it looks like a inverter optoislotor try to have a pull up resistor of 10-30mA and feed off the high side.
when I designed a circuit like that it's setup_fallout2_2.0.0.10.part2.rar the way that you would think is noninverting but is not, had no end problem working that out
hen918
Fri Jan 19 2018, 11:09PM
hmmm, the issue with push pull at a high voltage / power is that the energy stored in the leakage inductance is dumped into the opposite MOSFET body diode on every cycle. At higher powers you end up with large currents flowing, so the energy increases, as does power dissipation, as you increase voltage you put many more turns on the transformer, which increases. Note that the designs you link to are forward converters, which whilst not being very space (or power) efficient, are able to handle a few hundred watts.
If you look at the datasheet of the uc28025 the example is of a 50V 50W. Which is probably the limit of the non-resonant push-pull.
Sat Jan 20 2018, 04:06AM
hen918 wrote ...
i was hoping for 300 watts.
Ok what about a two switch forward type ?
hen918
Sat Jan 20 2018, 01:05PM
Nothing wrong with the two switch forward converter. You could make the design considerably simpler than the computer PSUs, throwing out the PFC, multiple output voltages and the shutdown controller.
I would recommend the half-bridge however, for it's simplicity and the full utilisation of the transformer. It would also be easier to change the transformer without having to change to many other components.
Sat Jan 20 2018, 08:25PM
Link2 another site ive found that uses TI and Unitrode info.
Im thinking about how the two equalizing caps values are calculated and the high side turn on.
Plasma
Sat Jan 20 2018, 11:11PM
Old circuit that shows a optoislotor driven a igbt
1516489918 61406 FT174221 Img 20180121 120328
Sun Jan 21 2018, 06:44AM
Plasma wrote ...
thats great i plan t mock up a steady state example soon, can you and a schematic and part numbers ?
Sun Jan 21 2018, 05:59PM
Nice work; please keep posting. Oh, and applause for nicely duplexing those utility boxes. Glad to see you abandoned the flyback topology in early part of this thread.
Making any mains-powered high frequency PSU will put you ahead of me. Have you considered, or already mentioned, hacking the secondary side of a computer PSU? Could even literally saw off the board near the isolation line.
