  • Guests: 11
cbfull (52)
Steve Ward (39)
05/19 cbfull (52)
05/19 Steve Ward (39)
05/20 Vaxian (17)
EMP BOX - TEST RESULTS - CALCULATOR AND LED CONNECTED TO A COIL...
1 2 3 4  last
Slava
Wed Nov 11 2015, 03:48PM Print
Slava Registered Member #518 Joined: Tue Feb 13 2007, 05:20AM
More results are in! ...
check out videos on page
I tested 3 designs... I am torn between two of them...
One of them can light an LED farther and resets a calculator, the other puts random digits on a calculator... but the LED range is less...
Any thoughts?
004
hen918
Wed Nov 11 2015, 06:39PM
Try adjusting the length of the spark gap and post results.
Thanks
Slava
Wed Nov 11 2015, 07:00PM
I made an error, .. the coil diameters are different.
10 TURN = 5.5cm coil form
5 TURN= 8.0cm coil form
008
In this test I used coils with the same diameter. Got different results. My power supply is running off of batteries, so try not to compare new results to old ones.
Wed Nov 11 2015, 08:30PM
NICE PROJECT
try a better spark gap, 'pointy' spark gap electrodes are (in my opinion) rubbish compared to large radius electrodes
(e.g. the back of two metal spoons or any curved objects), the gap will need to be MUCH smaller.
I suspect that for a given power supply / supply of power
the greatest range will be achieved by fewer but larger energy 'pulses' per second rather than many small ones
that means more capacitance and/or voltage ( E = 0.5 x C x V^2 )
The number of turns and diameter of the coil will have multiple effects;
. larger coils transmit farther
. fewer turns decreases 'Q' and increase frequency and peak current, stressing the spark gap, capacitors and wire more
. higher frequencies are likely to induce more interference than lower frequencies (use higher voltage / lower capacitance)
Having transmit and receive coils in the same plane as in your video has sometimes worked better for me than axially
circular coils tend to have a uniform field, square coils may work better in this case.
also, having a 'spare' high voltage generator and capacitors helps ;)
Slava
Wed Nov 11 2015, 08:38PM
Thanks for the tip. Right now I'm using screws as the gap... I redid my web page btw..
I need to figure out what setup is best... I'm surprised it works with other power supplies...
I built an EMP box long time ago and it turned out that the spark gap and resonant LC didn't do anything, all the RF came right from the power supply. I hate this because I have no control over it.
With this setup I tried different power supplies and it worked with all of them.
Signification
Thu Nov 12 2015, 02:10PM
IIRC, I got best results on an old coil coupling experiment that used a stationary round coil with a square coil as the distant "fine tune" element. I even used the degauss coil from a TV with some success (remove the "varistor" ??). I didn't try variation of the winding turns or caps (should have) then--just alignment effects for what I had.
Better be "careful" here...
Slava
Thu Nov 12 2015, 04:15PM
When I get home from class, I want to try a 20 turn coil...
Signification
Thu Nov 12 2015, 04:45PM
Slava wrote ...
I have more comments in mind, but it seems if you waited a bit longer between posts, you, I, and others, could get more information per post which will benefit all, do you plan on trying square or rectangular coil combinations, perhaps of certain dimensional ratios
...more later...
Slava
Thu Nov 12 2015, 06:44PM
Just tested, 3 turn coil and 20 turn coil...
008
002
Two inaccuracies in my test...
1) hard to tell when the led turned off
2) long alagator clips may throw off readings for low number of turns
Signification
Thu Nov 12 2015, 07:31PM
There's a maxima. An LC circuit can be represented mathematically. Simple differentiation can find the maxima patterns.
Can you fire a single pulse and capture it on a scope? You're looking for the maximum peak of an exponentially decaying sinusoidal...for starters...
1 2 3 4  last
