Multiple LCD displays on one digital picture frame
Sun Oct 18 2015, 09:07AM
Registered Member #96
Hi, need to do some brain picking here.
I have five frames, of which three work and two are dead. There are a number which share common components such as the display, obviously can hook up a socket to avoid painful soldering and risk of damage.
Need to multiplex two per system so the eyes are mirrored on each display, looks like reversing the front with the back also works. The problem is making sure the timings and impedance are right, ideas please? Using ribbon cables with the correct spacing is actually trivial, old optical drives have the correct type. EDIT:
thanks, -A
