Registered Member #3114
I want to wind a secondary for a flyback transformer and rectify its output fully. The didoes cost around ~$20 a piece and its not something that I want to fry being that I need 4 for full-wave.
Second part of this is calculating my output voltage. I want it to be around 8-6kv and around or below the current threshold of the diodes (more current the better).
If im using a ZVS flyback driver can I measure the output voltage of the driver(loaded or unloaded) and then use a voltage to turn ration to calculate the output? Or even a couple high value resistors and read the voltage that way?
Registered Member #1403
There is always the cheap solution of putting enough 1N4007 in series and assume 1kV rating for each added diode. You can build a 1MV rectifier for the same price as one those you linked to.
For voltage feedback you could use a voltage divider network as here:
Mads Barnkob wrote ...
I would do that but im not sure what kind of current my homemade transformer will be putting out. So using those larger dioeds i will have a 3A head room. Can I limit the output current somehow ? Might be better off using the larger dioeds so i dont have to worry about soldering all of them together and making sure they play nicely
Registered Member #11591
I find it unlikely that your transformer will output 40kW, or even 16kW. Personally I would just make 4 strings of 10 UF4007s or more if you are still unsure of your output voltage. Diodes play nicely in series. I've never had a problem. You can get 100 for $10.
hen918 wrote ...
You're probably correct. With that being said if I use this in a tesla coil fashion, wont the spark gap discharge create a spike in current possibly exceeding the ratings of uf4007s? Will the inductive kickback be an issue as well ?
EDIT:I usually order these instead of UF4007's for my higher current project Recovery Times are the same: 75 ns. Im just unsure of any inductive kickback or stress from the spark gap/capacitor. Is there anything I can do to shunt it or protect them ?
