  • Guests: 32
kg7bz (68)
steve516 (31)
05/17 Finn Hammer (72)
05/17 Blue Adept (43)
05/17 Nickel (68)
Post Your Cool Video Here!
Wed Sept 16 2015, 11:08AM Print
I thought it might be cool to see other's neat videoes. The video can be anything as long as it is impressive/pretty/impossible.
The rules are:
If it is "photoshopped" it must say so,
And it must be taken/edited by you.
Also it must follow the rules of the forum of course.
I'm interested to see what pops up...
-Mads Barnkob
Greatly inspired by the Post Your Cool Pic Here! thread.
Wed Sept 16 2015, 11:11AM
Some offshore helicopter videos
Late evening arrival at Gorm
Shuttling between two platforms in heavy 18-20 m/s wind and about 6 meter waves. It is hard to see, but they are really that big, just looks small when everything is big :)
The NEYi
Wed Sept 16 2015, 12:44PM
The NEYi Registered Member #55086 Joined: Sun May 24 2015, 03:18PM
Wow. smile
Well, I think my video isn't even close, but interesting in historical perspective.
That's Crimea several months before russian troops came in and annexed the peninsula.
It shows how it's peaceful sometimes right before war begins.
In the video itself I'm riding cableway which leads to the Ai-Petri, top of Crimean mountains, 1234 meters above sea. smile
Wed Sept 23 2015, 08:33PM
That is some long cable right there! What a long and beautiful ride.
A special prototype linear 8 cavity blow moulder machine for PET bottles, it was so impossible to get running stable that eventually it was discontinued and you can only get a 4 cavity today :)
This is one of the 2 in existence.
Thu Sept 24 2015, 09:22AM
Cavitation! I got to play with work's 16,000fps camera so I brought my cavitation-whisky-bottle of science that day! The bottle was filled with water then heated in a microwave (with the lid off) until it was boiling, then I put the lid on and cooled it off lowering the pressure to the point that it is almost just about to boil. One good whack on the cap and cavities break out.
Fri Sept 25 2015, 08:00AM
That is cool, assuming you did 30 fps, that should be around 8,25ms long.
Do you have a special light source for that camera to avoid flicker?
Sat Sept 26 2015, 05:57AM
I use 500w halogen lights for most of my high speed filming but this was done with a "50w" LED panel that had reasonable filtering on the PSU.
Mon Jan 18 2016, 07:57AM
Another video from offshore.
Here I am taking off from a hotel rig called Haven and fly around the Danish installation called Dan F, the largest and one of the oldest fields in the Danish part of the North Sea.
Feather-legged lace weaver (Uloborus plumipes) making a new web, what is different from normal spider webs is that this species uses carding with their legs, which can be seen working really fast in the video.
Dr. Drone
Fri Jan 22 2016, 10:58PM
shades
TwirlyWhirly555
Sat Jan 23 2016, 02:10PM
TwirlyWhirly555 Registered Member #4104 Joined: Fri Sept 23 2011, 06:54PM
This was my first attempt at time lapse stuff ,
I used a cheap camera and Arduino to trigger it to take a picture , it was set at 1 picture every 10 minuets , video is 9 days worth .
