Re: Post Your Cool Video Here! Mads Barnkob, Wed Sept 16 2015, 11:11AM
Some offshore helicopter videos
Late evening arrival at Gorm
Shuttling between two platforms in heavy 18-20 m/s wind and about 6 meter waves. It is hard to see, but they are really that big, just looks small when everything is big :)
Re: Post Your Cool Video Here! The NEYi, Wed Sept 16 2015, 12:44PM
Wow.
Well, I think my video isn't even close, but interesting in historical perspective. That's Crimea several months before russian troops came in and annexed the peninsula. It shows how it's peaceful sometimes right before war begins.
In the video itself I'm riding cableway which leads to the Ai-Petri, top of Crimean mountains, 1234 meters above sea.
Re: Post Your Cool Video Here! Mads Barnkob, Wed Sept 23 2015, 08:33PM
That is some long cable right there! What a long and beautiful ride.
A special prototype linear 8 cavity blow moulder machine for PET bottles, it was so impossible to get running stable that eventually it was discontinued and you can only get a 4 cavity today :)
This is one of the 2 in existence.
Re: Post Your Cool Video Here! Nik, Thu Sept 24 2015, 09:22AM
Cavitation! I got to play with work's 16,000fps camera so I brought my cavitation-whisky-bottle of science that day! The bottle was filled with water then heated in a microwave (with the lid off) until it was boiling, then I put the lid on and cooled it off lowering the pressure to the point that it is almost just about to boil. One good whack on the cap and cavities break out.
Re: Post Your Cool Video Here! Mads Barnkob, Fri Sept 25 2015, 08:00AM
That is cool, assuming you did 30 fps, that should be around 8,25ms long.
Do you have a special light source for that camera to avoid flicker?
Re: Post Your Cool Video Here! Nik, Sat Sept 26 2015, 05:57AM
I use 500w halogen lights for most of my high speed filming but this was done with a "50w" LED panel that had reasonable filtering on the PSU.
Re: Post Your Cool Video Here! Mads Barnkob, Mon Jan 18 2016, 07:57AM
Another video from offshore.
Here I am taking off from a hotel rig called Haven and fly around the Danish installation called Dan F, the largest and one of the oldest fields in the Danish part of the North Sea.
Feather-legged lace weaver (Uloborus plumipes) making a new web, what is different from normal spider webs is that this species uses carding with their legs, which can be seen working really fast in the video.
Re: Post Your Cool Video Here! Dr. Drone, Fri Jan 22 2016, 10:58PM
Re: Post Your Cool Video Here! TwirlyWhirly555, Sat Jan 23 2016, 02:10PM
This was my first attempt at time lapse stuff ,
I used a cheap camera and Arduino to trigger it to take a picture , it was set at 1 picture every 10 minuets , video is 9 days worth .
Re: Post Your Cool Video Here! Dr. Drone, Mon Mar 21 2016, 04:27PM
Ahhh
Re: Post Your Cool Video Here! Artlav, Wed Mar 30 2016, 09:10AM
Big Xenon lamp turned into a box of sunshine:
Addressing some safety concerns of the above:
And some cute fluid dynamics from an oxygen-starved candle:
Re: Post Your Cool Video Here! Dr. Drone, Mon Apr 11 2016, 08:36PM
ahhhhh
Re: Post Your Cool Video Here! Mads Barnkob, Mon Apr 11 2016, 08:56PM
On my way home from work I passed a offshore wind farm.
The reef contains the first large scale offshore wind farm in the world, Horns Rev 1 (160 MW from 2002).
80 turbines are laid out as an oblique rectangle of 5 km x 3.8 km (8 horizontal and 10 vertical rows). The distance between turbines is 560 m in both directions.
Re: Post Your Cool Video Here! Mads Barnkob, Tue Aug 02 2016, 11:41AM
The shortest and most crazy rain storm I have ever witnessed, it lasted only a total of 3 minutes and left the streets flooded. I only managed to film 1½ minute of it, but that is still the part where you can see it picks up in pace and almost dies out in the end.
Re: Post Your Cool Video Here! Conundrum, Wed Aug 03 2016, 04:58AM
Lots of lightning?
Re: Post Your Cool Video Here! Conundrum, Sat Aug 13 2016, 04:57AM
I think this might be a power line arc but still cool nevertheless. It appears that whatever this is seems to be picking up debris and ionizing it.
Re: Post Your Cool Video Here! Nik, Thu Dec 22 2016, 05:05AM
I build a Paul Trap from stuff you all own. Totally worth the half hour of work.
/borked the embedding
Re: Post Your Cool Video Here! Mads Barnkob, Thu Dec 22 2016, 07:33AM
Nik, Great results from a simple experiment, i will definately try that :) Great video.
You only need the video code in the embed tag.
Here is a small bug that took long to film in focus, while it did its rather special recovery from stuck on back.
Re: Post Your Cool Video Here! Uspring, Fri Dec 23 2016, 12:44PM
Neat experiment, Nik. Did you use a line driven NST as high voltage source?
Re: Post Your Cool Video Here! Nik, Sun Dec 25 2016, 05:48PM
Good recovery for that bug, I wonder how similar its walk cycle is to it's recovery flail.
The NST was on a variac to bring the output down to ~3-5kv. It worked better to start with a low voltage then crank it up and catch particles once they are close to being trapped. I also put ~20Mohm in series with each leg because I had to manipulate things near the electrodes, not there to make it "safe," just to make it less deadly should a light or camera get too close by accident.
Re: Post Your Cool Video Here! Enceladus, Thu Feb 09 2017, 08:05AM
