  • Guests: 13
a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
05/09 Coronafix (51)
Best practice with git, and why
Dr. Slack
Wed Sept 02 2015, 05:05PM Print
I'm using git to safeguard an application I'm working on. It's got beyond the toy application stage, several libraries, several tens of classes. Unfortunately, I've not used git, or any source control software before, and beyond doing a commit -a with sensible comments, don't really know what I'm doing, or how it's going to help. I guess I'm trying to throw myself in at the deep end to see what source control can do, having not really understood the advantages or the workflows from just reading about it.
Now I come to add a new function, and realise that it's getting messy because some of my classes are rather badly partitioned. So I need to refactor, and know that I will probably break it several times before the better class design is working.
So do I create two branches, one for refactoring and one for new function experimenting, or use head for one of those? And why? What quirks will I discover about the process that makes a difference to how I should use it? Are there any links that will direct me how to use it to best advantage?
Carbon_Rod
Thu Sept 03 2015, 12:54AM
Many projects have developer and stable versions.
Branching-and-Merging:
free book:
Git can be a bit of a liability on public networks...
wink
Dr. Slack
Fri Oct 30 2015, 07:45AM
I think I have an answer of sorts
1446191047 72 FT172880 Git
with the tool-tip text of
"If that doesn't fix it, git.txt contains the phone number of a friend of mine who understands git. Just wait through a few minutes of 'It's really pretty simple, just think of branches as...'; and eventually you'll learn the commands that will fix everything."
