  • Guests: 16
Vaxian (17)
05/21 Dalus (34)
05/21 Kizmo (37)
05/22 Skynet (32)
HELP ME print pdf
Thu Oct 12 2006, 10:01PM Print
Can anyone help me?
My Epson 400 Black is broken, leaving Cyan, Magenta and Yellow.
How can I 'trick' the pc/printer into printing Black & White pdf documents in ANY colour?
Thu Oct 12 2006, 10:18PM
If the printer prints already (ie it doesn't just sit there blinking until you put in a new cartridge) then you COULD use the picture select tool in the reader program, and copy the image into your favorite editing program (heck, even m$ word could be made to do it with a little trickery) and switch the black for blue... But that would be slow as heck wink
Short of that the only thing I can think of is a new printer, they are dirt cheep these days--usually about the same as it would cost for a full set of ink cartridges for an existing printer.
Fri Oct 13 2006, 12:15AM
I have an Epson 400 and its black is broken too. sad I couldn't find any way to do what you want, so all I can do is sympathize (and try to unclog the nozzles with IPA somehow)
Bjørn
Fri Oct 13 2006, 12:53AM
Some printer drivers will use colour ink instead of black if you set the quality to maximum(photo). I know someone that found that out after emptying an expensive colour cartridge by printing text.
That was a HP printer so it may not work on Epson.
Fri Oct 13 2006, 01:54AM
ok thanks ...tried fine/photo - still no good.
Looks like I'll have to get a new printer.
EDIT Can I lock a thread I started? How?
If not
MODERATOR please lock.
Bjørn
Fri Oct 13 2006, 03:23AM
Only moderators can lock threads with this forum software.
