  • Guests: 14
Shaun (34)
Spedy (30)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
Downs Cell Electrical Insulator
Thu Feb 05 2015, 10:38PM Print
I'm currently looking into building a small Downs Cell for making Sodium metal, mostly for the sake of seeing if I can do it.
the problem I have is trying to find a suitable insulator for the terminals that won't be effected by the high temperature of molten NaCl
Does anyone have a good idea as to what I could use?
thanks.
Thomas
Thu Feb 05 2015, 11:35PM
seems complicated
for sodium metal you could try something like this Link2
this video shows sodium by electrolysis with an easily available electrode/crucible Link2
Thu Feb 05 2015, 11:55PM
Sulaiman wrote ...
seems complicated
That's true, however It's not very pure... and not quite as fun!
The concept of a high temperature insulator is the main issue...
Ideally it needs to not get corroded by molten salt and be able to withstand temperatures of over 800 Degrees *C
Other then that, no problem!
Fri Feb 06 2015, 01:17AM
added one url above
Sodium metal on eBay Link2
hardly seems worth the effort, except for the learning experience of course.
Fri Feb 06 2015, 08:29AM
Sulaiman wrote ...
added one url above
To the same degree it hardly seems worth building a go cart, tesla coil, your own house etc.. as someone else has done it for you.
Fri Feb 06 2015, 11:09AM
for small quantities could you just use a borosilicate/pyrex 'U' tube
and insert anode and cathode from above, one each side?
you could use nichrome wire for electrical heating and possibly for both electrodes,
Wikipedia: Na melts at 98C, NaOH at 318C, Nichrome at 1400C and borosilicate softens at 830C, .... should be do-able
when the process is finished just smash the cheap/disposable tube under oil to retrieve the sodium for refining.
I have not tried, just an idea.
making or using large quantities of sodium is of dubious benefit shades
Did you look at the second youtube video that I pointed to?
it shows a simple ceramic crucible with electrodes.
Wastrel
Fri Feb 06 2015, 02:54PM
Wastrel Registered Member #4095 Joined: Thu Sept 15 2011, 03:19PM
Here be dragons. I recommend reading the sodium thread at sciencemadness from start to end.
Aside from chlorine being a war gas at the melting point of sodium chloride sodium metal has a vapour pressure of about a third of an atmosphere.
Molten sodium hydroxide eats glass.
Fri Feb 06 2015, 03:05PM
also, molten sodium eats glass
D'oh ! ....... sorry ! a completely stupid idea cry
Fri Feb 06 2015, 07:45PM
Sulaiman wrote ...
Ah yes, that is not the same method as I want to go for, It is much less pure. I specifically want to use Molten Sodium Chloride so I can get the pure Chlorine and Sodium from the electrolysis I intend to use the Chlorine to make Hydrochloric acid & Hydrogen Peroxide(why not?) and the Sodium for fun / other science stuff.
I intend to have a stainless steel setup made by a machine shop next door who can do it for me cheaply.
Or71KVHs
Ash Small
Fri Feb 06 2015, 11:13PM
Chlorine is THE worst enemy of stainless steel, especially 304.
Liquid sodium 'may' dissolve some of the metals in the alloy, not sure. (molten aluminium dissolves a bit of iron, for example.)
