  • Guests: 25
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Packing dll into single exe file
Linas
Sun Feb 01 2015, 08:47AM Print
Hello, not too long ago i started to program in Visual Basic, because i want to make lightweight application for DSP flash programming
Rignt now i am using labview, but in few days time i was able to remake it in windows form application
Problem is, that FTCSPI.dll is not included into exe file, is it possible to make my applications in a single exe program ?
]debug.zip[/file]
1422780464 1143 FT0 Untitled
Andy
Sun Feb 01 2015, 05:15PM
Depeding on the size you could put it in a array then create a file and copy, the normal way is at the bottom of your program put a marker say 41414141 then in the program use a egg hunter find the marker and cipy from the exe to another file, or just download a questioable packer program.If you need basic C code which you can convert to Vb will write it up.
Edit
It would be easyer to dynamic load the dll before use with Loadlibary(path,settings), then the program shouldnt complain until its called, just extract it beforehand, otherwise you need to right code the goes in just after its setup the seh and before calling main and loading dlls, but after kernel32 got loaded, then seach for the marker, create a file copy it to that, the jmp to or carrying after the hunter.
Linas
Sun Feb 01 2015, 06:41PM
Andy wrote ...
Edit
As i stated, i just started to work with windows programming , so it will take some time for me to understand what you just said.
it looks like where is source code for dll file, does that helps my purpose ?
it looks like c++ program, just question, how can i add this to my vb program ? Link2
Shrad
Sun Feb 01 2015, 08:09PM
for what I see this is .NET 4.0
you should be able to configure the project to include assemblies and resources in the compiled .exe file
this is from the set of parameters found when you right click the root of your project in the project explorer (or from the assembly itself I don't recall very well)
If needed I can check tomorrow at work where all my gear is
Linas
Sun Feb 01 2015, 10:32PM
I was searching for nay options that will do just that, but was unable to
If any one want to give a go, project for VisualStudio 2013 is attached, this is simple SPI Flash programmer via ft2232 chip
]d2xxaccess.zip[/file]
Andy
Mon Feb 02 2015, 01:42AM
Linas, its easy to write in charts.
Pe header
Seh code
Dll loader(kernel32,ntdll)
Egg humter and file creation with memcpy to file from exe to file created.
Dll loader continue
Main call
Program
End of program
Mark
Dll program
You will need pe explorer to fix the header checksum and other stuff can be done, pretty much I was saying above but the egg hunter line I will write in asm, and a second program that will search your exe and load the asm, you just need to run pe explorer to fix the checksum.
Shrad
Mon Feb 02 2015, 10:56AM
it should be a right click on your assembly in the project explorer view, properties, and setting Embed Interop Types to true,
that should include what you use from the assembly in the target assembly (your .exe) on compilation
