  • Guests: 22
04/28 Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
Circular railgun?
1 2 3 4
BigBad
Wed Jan 21 2015, 02:05AM Print
I was toying with the idea of making a circular railgun. I figure if you bend the rails around in a near circle, and used a ball bearing for the projectile it could get up to a fair speed.
It might be possible to do it in the bottom of a jam jar and use aluminium foil for the contacts. You need rigid sides to minimise rolling resistance.
If there's a scoopy thing, perhaps I could use an electromagnet to time the release and fire it out the scoop when it reaches top speed by sliding it over a bit maybe.
Wed Jan 21 2015, 09:02AM
the principle sounds workable
but in a glass jar ?!
how about something like
model railway track glued to the inside of a pvc pipe?
DerAlbi
Wed Jan 21 2015, 10:06AM
A railgun is a device that is particulary known for its wear and tear of its rails. I do not think that you could use aluminum foil for contacting. the movement alone will produce plasma/arcs that will consume your foil in no time, dont you think?
Even with just placing a ball on 2 parallel wires will make the thing practically questionable. It will kind of float on its plasma and since the ball is not restrained down with pressure the contact will be horible. I dont know if you ever watched a trams wheels on the rails.. even with that pressure you sometimes see it arcing.
But yeah: interesting idea. you are practically limited by radial forces only and you could have a quite long acceleration distance in a good form factor. the increase of speed will actually put some pressure on the rails... hmmh.
First electromagnetic accelerator with an inherently spinning projectile tongue haha
Shrad
Wed Jan 21 2015, 10:17AM
totally imaginary concept but very related... if you have a torus in which the interior had two conductive zones acting like rails, and a bead of mercury which would act as the shell, would it accelerate and evaporate and form a rotating plasma in the torus?
I guess the conductive rails would have to be superconductive and contain nothing but the mercury
accelerating a projectile would be easily achieved in a circular accelerator, but for a railgun it would be really difficult to design a mechanical path disconnection which would be applicable at such speeds
dexter
Wed Jan 21 2015, 03:38PM
first alot of force will be wasted in the radial direction
2nd the above looses depends highly on the radius - the smaller the radius the bigger the looses - to such extent that at a certain radius the projectile would stop inside the loop or even burst through the rails
also the projectile will move in a straight line after leaving the gurved rails - so no curve the bullet still remains in the fiction world :)
if you have the materials build it regardless of how counterintuitive it sounds
BigBad
Wed Jan 21 2015, 05:46PM
DerAlbi wrote ...
The thing is the current is a lot lower, with a normal railgun you need super high current to get decent speed before the end of the rail, with this you can go around lots of times at lower acceleration.
You're still going to need to wind up the voltage though, the top speed of a railgun is limited by the back emf of the rotor; it's actually a form of universal motor.
Sulaiman wrote ...
PVC is really too soft, you'll get lots of rolling friction; you need something really hard like steel or glass.
wrote ...
No, the radial isn't (directly) lossy. The friction force is lossy; which is proportional with the rolling friction (and the radial force.) For steel on steel or steel on glass, that's going to be pretty high.
wrote ...
Yes you probably wouldn't want two rails with a gap between them; although if the ball bearing weighs a gram and the g-force is a 1000, then that's only a kilogram force; 10 N.
wrote ...
I think that's rather the point if we can work out how to do the release mechanism! ;)
Shrad
Wed Jan 21 2015, 07:07PM
lower current times the number of passes required to achieve the wanted speed... as soon as friction damage from much more passes does not exceed one high power shot damage yes, but I don't think that would be the case
BigBad
Wed Jan 21 2015, 11:01PM
It's just a slip ring; they can have pretty decent life.
Shrad
Thu Jan 22 2015, 08:55AM
I think that due to current flow, movement and conduction losses at the interface would induce more stress and ablation with multiple passes at a low voltage/power than one pass at high voltage/power
You can always use a kind of conductive lubricant like graphite, on rails in a material which produces a conductive oxidation layer
I could well be wrong as I have no practical experience in railguns ;)
BigBad
Thu Jan 22 2015, 05:48PM
There's going to be pro and cons but a lot of it is i^2 R heating of the slip ring, and i is low.
