  • Guests: 15
Matthew T. (35)
Amrit Deshmukh (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
MUSHROOM DRSSTC
Thu Jul 17 2014, 09:41PM
That's an awesome coil, it makes me want to dig mine out of the basement and start rolling some more capacitors...
kilovolt
Fri Jul 18 2014, 07:43AM
Wow, again, that's an awesome project, zilipoper! Nice results and great setup (on the other hand we do not know anything other from you than amazing projects smile smile)
Thank you very much for posting!
Best regards
kilovolt
Fri Jul 18 2014, 08:03AM
zrg wrote ...
Actual public perfomance is a bit less amazing however :)
It's really amazing that it actually worked a bit during tests
:(... I guess at least it didn't catch fire or explode and ruin your hard work. Some sort of glitch in the control circuitry?
Fri Jul 18 2014, 11:31AM
I would love to know more stats about this.. :)
Max power draw?
Peak Current and so on!
Really quite awesome.
zilipoper
Fri Jul 18 2014, 12:06PM
zilipoper Registered Member #4152 Joined: Thu Oct 20 2011, 10:18PM
Thomas W wrote ...
Max power draw?
hi
yet there was none of the normal run
hi Goodchild
very pleased to hear
I will try to get on your teslaton amazed
Dr. Drone
Fri Jul 18 2014, 09:34PM
shades
Sat Jul 19 2014, 09:10AM
Wow... that sound in your test video, that is some scary shit!
Just the amount of copper in the bridge, great Russian overengineering :)
Are you lucky enough to just find abandoned industrial buildings where power is still on?
radhoo
Sat Jul 19 2014, 11:37AM
Amazing construction, love it!
Intra
Tue Jul 22 2014, 09:20AM
Intra Registered Member #2694 Joined: Mon Feb 22 2010, 11:52PM
SWEEEEEEEET!! ^______________^
Bridge design - suddenly excellent. Keep it up!
zilipoper
Thu Jul 24 2014, 07:49AM
hi
next start MUSHROOM DRSSTC
somewhere around the resonance cheesey
current primary 6kA
power input approximately 28 kW
this is not the maximum burst (punches magnifer)
Yy
1406188055 4152 FT164773 Acmepcd8ts4
1406188094 4152 FT164773 Bk4t0ylmkeo
1406188094 4152 FT164773 Eqiwli1vlky
9dlma6bai
1406188144 4152 FT164773 G Tfonglwso
5hhn8bje
1406188176 4152 FT164773 Krri74cytwo
1406188194 4152 FT164773 Xdoipzumite
1406188194 4152 FT164773 Yfth76pq4qi
