  • Guests: 22
Matthew T. (35)
Amrit Deshmukh (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
100W 6P45S mono block tube amplifier
Sun Dec 01 2013, 02:23PM Print
The idea to build these amplifiers came with purchasing a set of old studio monitors, the legendary JBL 4333. These 75 Watt speakers with 15″ bass drivers needed a amplifier that could deliver some more punch than my 20 Watt EL34 amplifier.
Huben Panev here from 4hv helped me source twenty 6P45S beam power tetrodes, tv sweep tubes, the equivalent of PL519. The original plan was really to build a VTTC with 20 tubes in parallel, but balancing issues with 20 tubes with very different characteristics due to being used was a major setback for that project.
A big thanks to Steve Conner for helping me sort out various mistakes, improvements and fault finding :)
The complete article with all pictures, information etc: Link2
DONE:
Prototype microcontroller software
Prototype enclosure
Prototype amplifier circuit
Prototype power supply
Start up and test with tone generator
Measurements with oscilloscope
Music test
Final enclosure
Final amplifier PCB
Final power supply PCB
TODO
Measurement and shutdown hardware
Measurement and shutdown software
I based the design on a rebuild of a old Easteuropean amplifier, the APX-100, Claus Byrith EL34 and a amplifier called KT88 Beastie from user Kruesti on diyaudio.com using long tailed pair for balancing the pre amplifier and phase splitter stages.
It it possible for the 6P45S to deliver approximately 120 Watt and will also have their bias adjusted for around 100 Watt, but will never be driven harder than the 50 Watt output transformers can handle.
I plan to build in a AVR microcontroller for showing voltages and currents on a LCD, making output stage adjustments/balancing easier and emergency shutdown to protect speakers automatic.
Monostage schematic
1387402179 1403 FT159404 Monostage
Power supply schematic (OBSOLETE, look for most recent version in latest posts, these schematics are kept as they were valid for the prototype)
1387402180 1403 FT159404 Psu
The prototype is built from scrap materials and BirdNestTechnology 2.0
1385907201 1403 FT1630 Gs6a2417
Choosing the values for power supply resistors
1385907201 1403 FT1630 Imag0064
The prototype finally working.
1385907201 1403 FT1630 Imag0065
Shrad
Sun Dec 01 2013, 08:31PM
yay, I just have four of them in a box somewhere... I just have to dig for them now! thanks for this contributions!
Wed Dec 18 2013, 09:29PM
Edit: OBSOLETE SCHEMATICS, look further in the thread for latest schematics.
Updated schematics with corrections and especially PSU have had a lot of changes.
Shrad
Thu Dec 19 2013, 08:51AM
I'm really amazed at the 100W rating you mention... I always thought a pair would deliver something like 20W at its maximum, as a tube can deliver 35W max rating as in the datasheet of the PL509
I should really dig for my tubes and start my own amp... something for the holidays ^^
Fri Dec 20 2013, 08:40PM
Here are the wave forms from yesterdays testing.
From wave of lowest amplitude to largest it is 23V(73VA), 26V(92VA), 28V(107VA) and 30V(123VA). I used a dummy load of 7,3 Ohm.
These numbers are of course the peak voltage across the resistive load, so the power output at 123VA with a guessed efficiency of 0,85 would be 74 Watt RMS.
The HF response is not quite as good as expected and I will do some more tests with different NFB circuit values to see if I can lessen the amount of rounding on the rising edge.
1387572038 1403 FT159404 1khz
1387572038 1403 FT159404 5khz
1387572038 1403 FT159404 10khz
1387572038 1403 FT159404 20khz
Sigurthr
Fri Dec 20 2013, 10:21PM
Before you rework the NFB you may want to do the music test. This is an audio amp after all, the HF components in a 20kHz square wave should be above human hearing. If there isn't truly significant dampening of a 24kHz sine then I'd call it good. Just my two pence.
Sat Dec 21 2013, 10:03AM
Sigurthr wrote ...
You are right, I talked with Steve Conner about this last night and looking at the wave forms there was only a drop from 28,4 Volt at 1kHz to 27,2 Volt at 20kHz, so it is only -0.375dB.
Today I will do some tests on -3dB of clipping power and find the -3dB lower and upper frequency. Then I will decide weather to experiment further with NFB values.
Edit:
I tested the above with my 7R3 resistive dummy load and a 8R speaker. It seems there i absolutely no reason to change anything on the amplifier. The square wave tests showed some rounding that should be expected on 10kHz as the transformer can not pass the 100kHz harmonics. The sine wave tests shows great linear band width.
3db Test
Shrad
Sat Dec 21 2013, 07:23PM
definitely a winner amp, for a simplicity and price point of view, and the fact I have everything in my bins ^^
after chritsmas I'll have gathered a big copper plate for making a chassis out of copper and nice wood :)
Sigurthr
Sat Dec 21 2013, 10:09PM
It really is a beautiful piece of work. I'm just glad I was able to help :) .
Sat Jan 04 2014, 07:12PM
Second performance measurements after NFB capacitor is changed from 1nF (41kHz cutoff) to 0.47nF(87kHz cutoff), the bandwidth of the amplifier was increased and clipping occurs at higher power than earlier measurements.
The prototype is now considered done as it has proved itself capable of outputting 210 Watt peak before clipping. At 100 Watt peak it have its -3dB points at 11 Hz and 72 kHz.
I forgot to set the V/div correct, so all voltages should be multiplied by 100 or just read them with one decimal like 39.2mV is 39.2V
1388862628 1403 FT1630 Firkant 400hz 20khz
3db Test
