  • Guests: 16
cbfull (52)
Steve Ward (39)
05/19 cbfull (52)
05/19 Steve Ward (39)
05/20 Vaxian (17)
DIY Solder Paste Dispenser
Dr. H.
Fri Jun 27 2014, 01:16PM Print
Hello guys
Due to my recent "migration" to mainly SMD components in my hobby work (and I really wanted to play with some pneumatics) I've decided to make a DIY paste dispenser (using compressed air). The idea was to have everything in one relatively small enclosure (this includes the air compressor and air receiver).
After a lot of digging a good candidate emerged - a compressor for air suspension (the one I used is from BMW E39 wagon). All of the unneeded parts were removed and a new "pressure plate" was made for attaching a hose.
A toroidal transformer is used for powering the 12V compressor. A small extinguisher is used as air receiver and some 24V valves are used for the air "switching" cheesey.
Well here is the progress on the project smile
Cheers
1403874897 931 FT0 Img 20140601 101351
1403874897 931 FT0 Img 20140601 101532
1403874897 931 FT0 Img 20140601 150440
1403874897 931 FT0 Img 20140607 171624
1403874897 931 FT0 Img 20140607 173226
1403874897 931 FT0 Img 20140608 225119
Dr. H.
Mon Jun 30 2014, 08:09AM
Hi guys
so a bit of a progress on the project. The concept works smile Time to place everything in the box.
Cheers
1404115760 931 FT164214 Img 20140609 233733
1404115760 931 FT164214 Img 20140611 185109
1404115760 931 FT164214 Img 20140617 204534
Dr. H.
Thu Jul 03 2014, 07:37AM
Hi guys
moving forward on the project. The PCB arrived - assembled and placed in the box - amazingly everything fit in the box ill
Time for SW ... ugg ....
1404372460 931 FT164214 Img 20140612 220046
1404372460 931 FT164214 Img 20140622 224559
1404372460 931 FT164214 Img 20140622 224611
Dr. H.
Mon Jul 07 2014, 05:19AM
Hi guys
the software is roughly complete ... well the preliminary version at least. For now it seems that the device is performing as designed. Soon I will be assembling some smd boards -will test it thoroughly then.
To regulate the pressure a differential pressure gauge (MPX5500) is used. It keeps the pressure across the air regulator at 4 bar (adjustable through sw) with a hysteresis of 2 bars (also adjustable). With a 1 litter air receiver about 35 "clicks" can be made before the compressor starts pumping again.
P.S. The dots that appear to be the same size - used the "automatic" time dispensing.
Cheers
1404710354 931 FT164214 Img 20140622 225314
Linas
Mon Jul 07 2014, 01:44PM
compact, but messy.
Good to see new projects smile
Dr. H.
Tue Jul 08 2014, 12:36PM
Hi Linas
yes - a bit messy indeed. I couldn't find smaller valves (for reasonable price) so those big lumps ate a lot of space, and one of the main requirements was to be very compact so I can keep it on my desk - mission accomplished smile.
Yesterday I did a test - I managed to solder about 220 components (0805 and 0603, sot23, sod123 - all in all not very small packages) in 2 hours of work. Much better productivity compared to me with the soldering iron hee hee - and looks much better. Will post pics of one of the assembled boards soon.
Cheers
Tue Jul 08 2014, 12:55PM
Another thoroughly well done project by you Huben and a perfect example of how we spend most of our time developing the tools to make the parts we need for our much smaller projects :)
The envy can really be felt when I see your front plates from your own mill.
What does the dispenser head look like that makes the drop?
Linas
Tue Jul 08 2014, 01:46PM
This is what you can get in 5-10$ stencil, paste dispensing take only few minutes, but component placement take additional hour or two, and my smart solder reflow oven did the rest in 5 min.
Since i make my pcb in OSH Park, from now one i don't spend to much time on soldering :)
1404827171 1143 FT164214 1
Works down to 0201 ( LVDS termination near FPGA )
Dr. H.
Tue Jul 08 2014, 03:58PM
Hello guys
Mads - thanks for the nice words smile I've attached a pic of how the business end looks like. It is a standard 10cc solder paste syringe. The adapter at the end is a standard component (it is the same for 10cc syringes with glue, solder flux etc.). Very cheap from e b a y.
Linas - thanks for the reply smile You should know that there is more than one way to skin a cat. The boards I assemble are more of a high power stuff, not BGA and 0201. So my needs are for something a bit more crude (don't understand me wrong - I've placed 0402 and I am sure 0201 won't be problem with this dispenser - just use smaller needles). Of course I agree - stencil is the way to go - but why bother for 20-50 even a 100 components for single boards/runs. Dispensing the paste for the board from the pic takes about 2 mins for each side - why bother with ordering and (mainly) waiting and delivery of the stencil ?!?
Cheers smile
1404834987 931 FT164214 Pic 1
1404834987 931 FT164214 Img 20140708 183520
1404834987 931 FT164214 Img 20140708 183822
Linas
Tue Jul 08 2014, 08:01PM
well, if i order PCB from OSH park, i will order stencil from OSH Stencils, and i will gat stencil first.
I developed technique for small runs by simply tinning all contacts with solder iron, and it will give just right amount of solder, but in that case each component should be placed manually.
I just picking on you, we all know that is good tool to have smile
Add CNC and you will have super solder paste dispenser, i guess you are working on that, right ?
